You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hay all i just got a 2003 f150 king ranch with the 5.4 in her. I found a supercharger off a Harley edition on crieags list and it seams to have all the parts. What would be intailed in instaling it in my truck. would i need any other additions? a new wiering harness for the added sensors or any thing. or it is just a plug and play bolt on?? any help would be awasom because i'm totaly stumpes.
After you have bought an OE Supercharger, Manifold, Intercooler, etc complete with injectors and engine wiring harness, you will need most of the items listed below.
INSTALLATION PARTS LIST
Bracket with idlers and special bolts
Tensioner Assembly
Lightning Alternator
Alternator Stabilizer Bracket
Intercooler Pump with Bracket and Pigtail
Intercooler Reservoir with Cap
IAC Tube
Throttle Cable
Throttle Cable Bracket
Cruise Control Cable
IAT Sensor (fits in air cleaner)
Lightning Water Pump (or suitable substitute)
PCV Tube (left hand side)
TB to MAF Rubber Connector with clamps
90mm MAF
Intake Gasket Set
In-Tank Fuel Pump
Upper Radiator Hose
Upper Two Intercooler Hoses
Original Equipment Installation Bolts
Drive Pulley with Belt (Boost level of your choice)
