No Overdrive 1990 F-350 7.3L Diesel
I have a 1990 F-350 7.3L Diesel and I can't get it into overdrive. The switch light seems to stay on no matter the position and my transmission selector seems to be misaligned (P R N D 2 1). Also my tachometer is not working but I am not sure if this is coincidental. Anyone have any ideas on this? Thanks.
Well I check the fuses, cleaned up the OD lockout switch tested it and reinstalled but I still have the issue of the OD being disabled. As soon as I start her up the OFF light is on and pressing the button has no effect. I am waiting for service manuals but in the meantime I was wondering if anyone had any ideas. The tachometer does not work as well. Where is the ECM on a 1990 F350 diesel? Thanks.
Well I have electrical diagrams, ODB 1 reader and I am going to look into fixing my tach. I did find that there is a 3 conductor connector under the dash that is not connected to anything and I suspect that this is my tach sensor. The fact that it is not connected to anything is a good indicator that this is why it is not working. Does anyone know where this connector should go? It is not obvious looking under the dash. This wire comes right through the firewall down around where the big wire connector feeds through the firewall.
blackturbo
12-28-2013 07:48 PM
labinepoirier
05-29-2013 03:47 PM
