where is the best place to get a rebuild kit for my 390
my 390 is done it has low compresion and burns oil i just want to put new standard rings in it give it a valve job and new main bearings seals and the like. Where is the cheapest place to get a basic rebuild kit.
you may consider just trying your local NAPA and asking for the car 2v kit instead, ask for say a 1965 Galaxie with a 2 barrel and 3 speed automatic, it should give you a bit higher compression which will mean better gas milage...
