Define this data plate & axle photo - Ford Truck Enthusiasts Forums
Old 10-05-2007, 01:05 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.
Here's the info data plate & picture of the rear axle from my buddies 77 F100; So many members stated that it couldn't have a vin number for axle code of 46J. Well I posted a photo of both the rear axle & vin plate as well. I believe it was either a dealer option or special addition from OEM.
Mitch
Old 10-05-2007, 02:16 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
This needs to go in the original thread
Even in my newly arrived 77 shop manual there isn't any mention of a axle code 46.
I am thinking this is a special code for an F100 with a Dana 44.
GVWR axle weight is high at 4700 lbs so that would make sense,
Old 10-05-2007, 03:41 PM
Customcab's Avatar
Dennis;
I'm not too sure of how I was going to put this into the originial posting; I had to get a co-worker to help post it.
I guess the only way I can determine the ration is doing the jack up the rear end speed mentality?
How does the GVWR plan a role in determining rear axle?
I knew I wasn't lossing my mine on the axle code 46J; just my hair!
Mitch
Old 10-05-2007, 04:14 PM
quote: How does the GVWR plan a role in determining rear axle?
It's the other way around.
The specs of the axle/frame/suspension,etc determine the GVWR.
In all my experiences involving Ford Truck I don't ever recall seeing an F-100 with a Dana axle.
Old 10-05-2007, 04:36 PM
Customcab's Avatar
I guess the 46J code & rear axle not being the typical 9''; it could be a OEM install rear end. Trust me once I saw the code I surely was confuse in my reference's to fine it and determine the ratio as well.
Mitch
Old 10-05-2007, 07:24 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Just a quick note, there are two axle codes there, 46 is the Dana 44, J is for power steering / non tilt column.
1969 Ford Cummins Crew Cab Conversion HRDROKN Engine Swaps 686 12-28-2015 09:31 PM
LOL PinkStroker 1999 - 2003 7.3L Power Stroke Diesel 43 12-08-2010 08:46 PM
2010 Raptor on the lot!!! Several Pics (56K warning) powerstroke72 2010 - 2014 Ford SVT F150 Raptor 39 12-11-2009 02:54 PM
New stuff. Bet you've NEVER seen this before PinkStroker 1999 - 2003 7.3L Power Stroke Diesel 91 11-13-2008 11:51 AM
1975 Highboy 51dueller 1973 - 1979 F-100 & Larger F-Series Trucks 18 12-22-2007 01:37 PM
Tags
03, 2003, 46j, axle, code, codes, data, f150, ford, plate, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
