Idle way to fast, help! - Ford Truck Enthusiasts Forums
Old 10-05-2007, 11:31 AM
amexjoe amexjoe is offline
amexjoe is starting off with a positive reputation.
Hi folks,
I have taken all the air filter routing hoses out, dialed the idle screw off and then some. Vacuumed out what appeared to be a rodent nest.
Started the 1992 Club Wagaon 351w,a/c,auto
and she is idling wicked fast.
I am thinking vacuum line breach or timing.
I will check both, but in the mean time...
Many thanks in advanced for your advice.
Old 10-05-2007, 05:51 PM
blue beast's Avatar
blue beast blue beast is offline
blue beast has a good reputation on FTE.blue beast has a good reputation on FTE.
You shouldn't have messed with the throttle hard stop at all!! Disconnect the Iac control wires and see what it does. Did it stall or stay running at a crazy rpm? You need to back the screw down until it barely runs, then plug back in the IAC. You probably have to clean the IAC.
Old 10-06-2007, 08:40 AM
Hey man, thanks.
I disconnected the IAC, it stalled.
I am cleaning it now.
Old 10-06-2007, 06:22 PM
I cleaned all of the carbon out, the travel seems to be ok and it appears to seat properly, but it still idles very fast. I disconnected the IAC, set the idle manually and it seems to like it.
What damage can be caused if the IAC is left disconnected?
Thanks
Old 10-06-2007, 08:29 PM
blue beast's Avatar
the truck should idle at about 500 rpm with the Iac disconnected, adjust the hard throttle stop so it is around there. Did you unplug the computer so it could figure out the Iac is freed up?
Old 10-07-2007, 07:38 AM
IAC disconnected.
Hard stop adjusted.
idles at 500 rpm.
Old 10-07-2007, 11:05 AM
blue beast's Avatar
I meant for you to disconnect the battery so the computer will relearn, Hook the Iac back up it should go to about 750rpm and then when you put lights on, ac etc it should raise up a bit!! If you got a vac leak as well it will screw with the idle go over all of them especially those hard lines.
Old 10-09-2007, 08:22 AM
Thanks for the reply,
disconnected the battery, couple of minutes?
reconnected IAC,
wicked fast idle.
Vacuum lines seem ok.
Time for a manual override?
Old 10-09-2007, 09:40 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
spray fast start or carb cleaner over the vacum lines if the engine increases rpms then you found your leak
Old 10-25-2007, 11:18 PM
Canadawg Canadawg is offline
Canadawg is starting off with a positive reputation.
what about the voltage at the IAC. I am having a similar problem. Cleaned everything and checked the voltage. Its at 11.6v with the key on engine off when it should be 10.5v. Any ideas? Also I have a code 52, power steering preasure switch and I have read that it adjusts timing, could this affect idle as well?
Old 08-13-2012, 07:03 PM
update
ok, so its been a while,
cash flow was low...blah blah blah
i replaced the throttle position sensor and the idle dropped to 1412rpm.
the throttle body needed a bath, done.
acetone, what a joke, varsol rules, remove all things electrical first.
the vacuum port to vapour canister was clogged, fully cleaned.
it did pass the emissions test with the following @1412rpm
hc ppm 22
co% .04
no ppm 340
i am so in the manual override old school zone.
so any thoughts on how to setup a manual override for this idle air control valve?
i want the cockpit of this club wagon to look like the space shuttle!!!!
Old 08-13-2012, 08:42 PM
fixed
sometimes you just need a little faith...
unhooked the battery,
backed off the idle set screw until i saw daylight,
said a prayer
fully fabulously functioning fantastically from factory !!!!!
Old 08-13-2012, 10:17 PM
HD's Avatar
HD HD is offline
HD is starting off with a positive reputation.
Quote:
I tried to say that five times fast, and failed miserably.
Chris
How much is too much on the mixture screws? Squirrel Man Sam FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 04-12-2011 07:53 PM
Another idle speed question Superdave Modular V8 (4.6L, 5.4L) 2 12-16-2009 02:29 PM
352 hesitation off of idle Big Daddy T 1961 - 1966 F-100 & Larger F-Series Trucks 13 09-30-2009 09:30 PM
idling fast 1989 F-150 cavitill 1987 - 1996 F150 & Larger F-Series Trucks 4 04-16-2005 01:20 AM
Demon Carb Fast Idle Adjust bluesky636 Fuel Injection, Carburetion & Fuel System 5 08-08-2004 05:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
