I have cam card it shows 2000-5000 rpm. I have cam installed in my 390 and have had it to 6500rpm just wanting to know if anybody has same results.thanks
sfudge
Did it still pull hard at 6500? You may be better off shifting a little lower. What kind of bottom end do you have in it. Have you modified the oiling system?
Was still pulling hard @6500 when i let out of it. too much rpm for block to last. bottom end is balanced arp rod bolts. cast pistons flat top. just wanted to see how many rpm before valve float still don't know. cam is retarded 2 deg.
Thanks for the info. This is the 3rd cam i have tried this year. going to stay with this one for now. I thing i will put revlimiter on 5800 rpm shift lignt on 5300. should shift about 5500 rpm. im slow motor comes up fast on n2o.
