Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-04-2007, 08:03 PM
Red Star has a good reputation on FTE.Red Star has a good reputation on FTE.
Article from AUTOSAVANT
The base engine will be an all new 3.7 liter V6. This is a version of the D35 engine rapidly spreading through Ford’s lineup, and while there will be other 3.7l V6’s in Lincoln’s and Mazda’s lineup, the V6 in F150 will be unique, specifically tuned for low engine torque. While the numbers are not revealed yet, expect about 260 horsepower and 280 or more ft.lbs of torque at about 2000 RPMs.
Next up will be the venerable three-valve 4.6l V8 from the Explorer. This engine will be not modified in any way from its Explorer application so the power numbers will remain 292hp, and 300ft.lbs of torque. This engine is at its final years of production, and will be dropped shortly after the engine lineup is completed in the 2010 model year.
The third V8 at launch will be a new version of the 5.4l V8. Mostly using the Expedition setup, Ford has reworked the engine for more power, torque, refinement, and efficiency. The final numbers were not revealed yet, but 325hp and 380ft/lbs of toque is a reasonable expectation.
The first post-launch change in the powertrain lineup will occur in the first weeks of 2009. As a Job2 change, Ford will add a 6.2l V8 engine. This will be the first member of the BOSS family, and while the engine is still in testing, it is expected to be rated at around 425hp. This engine will be officially revealed and released a couple months prior in the 2009 Lincoln Navigator.
Final major change in the engine lineup will come with the launch of the 2010 model year of the truck in the summer of 2009. A new 4.4l V8 diesel engine and a TwinForce 3.5l V6 will be added, and, as mentioned above, the 4.6l V8 will probably be dropped. The diesel is a larger version of the 3.6l Lion V8 diesel Ford developed with France’s Peugeot/Citroen (PSA) automaker, and will deliver around 315hp and 520ft.lbs of torque. The Twin Force engine will be positioned as a V8 alternative with better fuel economy. Using twin turbochargers, direct injection, and twin independent camshaft timing, the engine will deliver about 400hp and 400ft.lbs of torque at 1500rpms.
It is unfortunate Ford will not launch the truck with the full engine lineup, and it will likely hurt the sales some; but with the rapid rollout of the remaining engines the damage should be minor. Moreover, Ford has a final ace up its sleeve; in the 2011 or 2012 model year, Ford will add a monster of an engine: a TwinForce version of the 6.2l V8 – delivering more than 650ft.lbs of torque and around 500hp. The new engine will deliver performance equal to, say, a Chrysler SRT-10, but with a smaller engine and better fuel efficiency. Like with the 2008 Super Duty, Ford is not playing around with the truck and aiming squarely for the “class leading” designation. We will see the truck at Detroit Auto show in January, and Job1 is on August 8th, 2008.
http://www.autosavant.net/2007/10/pr...ford-f150.html
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-04-2007, 11:49 PM
builtfordtough13's Avatar
builtfordtough13 is starting off with a positive reputation.
i'm really liking the twin force idea, especially the 6.2L version.
  #3 (permalink)
Old 10-05-2007, 12:43 AM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Man, some of this stuff is so bogus... I imagine there will actually be a v6/hybrid truck, a clean-diesel 6 cylinder, and possibly an updated Triton V8 of 6 liters, but I would expect 5.7 Liters.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
