v10 ignition coil replacement - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 10-04-2007, 12:44 PM
MABGADGETMAN MABGADGETMAN is offline
MABGADGETMAN is starting off with a positive reputation.
Question v10 ignition coil replacement
Does anyone know if there any illustrations online of how to replace iginition coils on the V10 and how to test which onwes are bad? the dealer charged $280 to replace 1.
FYI just had a new engine put in my 2001 oil pump went out at 107K i couldn't believe it.
Old 10-04-2007, 01:38 PM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Welcome to FTE, MABGADGETMAN!
To replace the coils, all you have to do is disconnect the power source, which is just a plug/receptacle, then remove a small screw. You just pull it up then.
As far as testing which ones are bad, it depends on how bad they are - that is - if they have failed completely or if they misfire intermittently. Hard to find them when they only miss under load, or right at start-up, or just a few times during the day.
The dealers have a diagnostic procedure whereby they locate failures through a piece of equipment called a WDS (Worldwide Diagnostic System). Pretty good at it, too, and charge anywhere from $50.00 to $125.00 depending on location and your PR with them.
$280.00 just for coil replacement is pretty steep. I think you can buy a coil now for $40.00.
Oil pump, huh? Sorry to hear about your troubles. Did you buy the truck new? Do all your oil changes and such?
Old 10-04-2007, 02:50 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
$280 to change a COP.
Thats why they call it the Stealership.
Big Orns got you covered.
Old 10-04-2007, 07:19 PM
dajkzo dajkzo is offline
dajkzo is starting off with a positive reputation.
It was time to replace the COPs recently, I went with the Accel packs from Summit Racing, they came with the wire and boot at $27 each. I was seeing the classic shudder in overdrive at 1700 rpm, no codes, and the packs ohmed out. (I hate static tests on coils)
Easy part to replace, except the last 2 on the passenger side, but even those were not enough to make me say &^$(#j(@
So far about 1500 miles and I'm happy with the performance.
2000 Ford Expedition xlt battery saver relay clicking no start websurfer Expedition & Navigator 13 11-14-2016 03:22 PM
MPG OVER HERE Rosson03 Excursion - King of SUVs 23 02-26-2011 04:32 PM
Auto locking hubs-2004 6.0 Diesel Excursion jeff2011 Excursion - King of SUVs 4 09-07-2009 11:54 PM
Some '09 SD information... PowerStrokeHD 1999 to 2016 Super Duty 4 03-10-2008 09:34 PM
Triton V10 Tune-Up Greem 1999 to 2016 Super Duty 3 10-01-2007 04:57 PM
Tags
02, bad, coil, ford, ignition, replace, replacement, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
