How ro replace rear axle seal on f350 srw? - Ford Truck Enthusiasts Forums
Old 10-04-2007, 12:41 PM
texcan's Avatar
texcan texcan is offline
texcan is starting off with a positive reputation.
Question How ro replace rear axle seal on f350 srw?
I've got a 94 f350 PS. The rear axle seal on the passenger side is leaking. How hard is it to replace? I've never replace one before but am good at repairs. How do you get it out, and replace it?
Old 10-04-2007, 12:58 PM
17fordguy's Avatar
17fordguy 17fordguy is offline
17fordguy is starting off with a positive reputation.
hope ya got jack stands
lift back of truck remove diff cover dismantle guts pull out shaft on both sides after removing wheel replace ALL seals noit just one side and then reasimble if i forgot any thing then your haynes manual should tell it.
rear axle semi floating or full floating? FordOwnerJoey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 11-06-2013 03:30 PM
Can't get rear axle seal to stop leaking ststock23 1999 to 2016 Super Duty 20 01-07-2013 11:03 PM
1997 ford f350 crew cab 4x4 DADS4x4 1987 - 1996 F150 & Larger F-Series Trucks 10 04-05-2011 10:59 AM
Axle Seal sdeforest 1997 - 2003 F150 1 01-17-2007 07:28 PM
'97 F350 axle seal Dieselman929 1994.5 - 1997 7.3L Power Stroke Diesel 12 04-05-2004 10:36 AM
Tags
1996, 2006, 44, 94, axle, end, f250, f350, ford, rear, remove, replaace, replace, replacing, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
