F350 Turbo Diesel Killing Batteries - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-04-2007, 11:18 AM
tjoegrind tjoegrind is offline
tjoegrind is starting off with a positive reputation.
I bought this 2003 Ford F350 Turbo Diesel truck from a dealer a little over a month ago; it worked fine up until one day last week. I got home from work I turned off the truck to open my gate and it would not start. It cranked a few times then it seemed like the batteries (2) started to go down. I checked the oil level and it was ok. I check all the fuses and they were all ok also. I have a BullyDog Programmer installed and set to tow/economy, so set the truck back to its stock settings and tried to start it and it started. I pulled into the yard and restarted it and it again started ok. I left it overnight and the next morning when I tried to start it, it seemed like the batteries did not have enough power to start it. I checked the Voltage which read 11.48 volts. I charged 1 battery and I noticed that the terminal was dirty so I cleaned it. When I reinstalled the battery it started ok. I didn’t drive it for about a week. When I got in yesterday afternoon it started ok I drove it around all afternoon turning it on and off with no problem (no weak starts or weak batteries). I activated the alarm and went to bed. This morning when I tried to start it, it was almost unable to crank. Batteries seem to be week again. Seems like something is draining the battery when it is parked. Does anyone have an idea what could be the problem?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
No lights or any other accessories were left on.
<o></o>
This is becoming a pain… any help would be greatly appreciated.
<o></o>
Old 10-04-2007, 11:53 AM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
if they are the factory batteries then its probably time for some new ones. when you are cranking the engine look at the volt gauge, what does it read? if it drops down to the bottom of the gauge thats a good sign you need new batts.
Old 10-04-2007, 12:00 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
You say "No lights or any other accessories were left on" but you also say you set the alarm, which takes current to run.
Yes, diesels in general are harder on batteries. This is why you have two. Relace them as a pair, otherwise you'll have other problems.
Inspect your entire charging system. Batteries are just one part of it. A weak alternator, bad cables. loose connections or an unknown current drain will also cause problems.
Old 10-04-2007, 12:12 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Most Volt Meters will measure current. To do it, lift the positive lead to the battery and connect the meter leads between the battery & cable. Since there are two batteries, you'll have to take the other positive terminal off, so you're only measuring drain from one source. I'm not sure what the "normal" current is though. I can measure mine when I get home. I wouldn't expect more than maybe 100 mA (.1 A). Like Redford said, there are other parts of the system that can cause this, but if you're sure the batts & alt are good, then there must be something pulling extra current from them.
FWIW, when one of mine got weak, it acted similar. I let it set over night and it seemed to start slow. I let it set about 5 days, and it almost didn't turn over (thankfully it did -- I was in an airport parking lot 2 hours from home). I ended up replacing the batteries (but only one was bad), then the alternator two months later. I think the bad battery put a serious strain on the alt.
Old 10-04-2007, 12:56 PM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
Alternator
I agree with some of what the others said. You may have bad batteries, but I think that it is more likely an alternator problem. What voltage do you read across the battery, either one, when the engine is running at idle with all accessories off. It should be 14.1 or better, up to about 14.7max. If it is outside of that range, then the alternator has a problem. More bad alternators have caused good batteries to go bad than the other way around. Turn on the A/C fan/blower to max and re-read the voltage across the battery. If the alternator is working properly, the voltage should not drop much. A little is OK. If the alternator checks out and you do not have something shorted draining the batteries, then the battery(s) is/are bad. You know that if you are unsure about the alternator, you can take it to most auto parts stores for a free test?
Old 10-04-2007, 01:54 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Yup, most parts stores will test alternators for free. I believe that they will also test batteries for free too.
Old 10-04-2007, 02:14 PM
Layson's Avatar
Layson Layson is offline
Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.
I think there should be a regulator that brings the voltage down to max of 14.1 ... mine usually runs about 13.7 to 14.1 and it is brand new..
You could have one bad battery that kills everything else...which will kill the alternator too..
So just like everybody said get some new batteries.
You could try giving them a real good charge with a charger...out side of the truck and then test them. ??
Old 10-04-2007, 03:18 PM
Hey Guys,
Thanks for all that valuable information. I really appreciate it. I know this might be silly but the batteries "Look new". They do not have the date purchased punched out, but both are the exact same Chrysler batteries. On an average, can you tell me about how long batteries should last? I also would not think that the alarm would use that much current. I'll check the alternator. I also find it strange that the batteries run down when the truck is off, which again leads me to believe that something is draining them. i'll try all your suggestions and let you know. Thanks Again ...Peace
Old 10-04-2007, 04:16 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
if you want to do it the lazy way take it to wally they have free battery check
Old 10-04-2007, 04:50 PM
Izzy351's Avatar
Quote:
Originally Posted by tjoegrind
Hey Guys,
Usually 4-5 years is about average in my experience. A shorted cell in a battery will kill them just sitting, too. Remember, they're in parallel, so if one gets weak, it will pull the other one down. That's what happened to mine. The PO replaced only one (it was only about a year or so old in April of this year) and the other was original. I went ahead and put in two DuraLast Golds from AutoZoo. So far, so good...
Old 10-04-2007, 06:04 PM
MisterCMK's Avatar
Avid Winter Hater
Hey Guys,
Looks can be deceiving. You have to start ruling things out somewhere and this seems like a good spot to start. Take the batteries and alternator up to your local parts store and have them test it out. That way there is no speculation.
Old 10-04-2007, 07:18 PM
Layson's Avatar
It will not start with bad batteries... so get those guys checked...
Old 10-04-2007, 11:36 PM
skinner00 skinner00 is offline
skinner00 is starting off with a positive reputation.
in az batterys seem to last 1-2 years
Old 10-09-2007, 07:49 AM
I had the batteries checked at NAPA and found out that they both where bad. they were not holding the charge. i also saw i sticker on them that said 6/07...not sure if that's when they were installed. In any event, they are bad. A local Mechanic told me that the only thing that would cause the batteries to go bad like that was if they went completley dead (which they didn't) or if they were overcharged and i had not charged them before the problem started. This laeds me to believe that the altenator overcharge the batteries. Does the 2003 ford f350 turbo diesel carry a external voltage regulator? If it does, can you tell me where it's located and how to test it?
Thanks
Old 10-09-2007, 08:02 AM
rbaker6336's Avatar
if it was a little round sticker that would be production date
think voltage reg is internal
2006 F 150 5.4 Triton motor, Fuel Injector problems & More AZRogala Computer Chips & Tuners 17 12-11-2015 04:30 PM
2011 F350 Towing Noise njload 6.7L Power Stroke Diesel 4 08-05-2014 01:09 PM
3 Post to 4 Post Alternator Question clarkbre 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-28-2014 10:40 PM
diesel exhaust on a V10 AZEX Excursion - King of SUVs 1 05-08-2012 09:39 PM
1997 F250 Crew Cab 4X4 Needs Overload Springs 38-72 1987 - 1996 F150 & Larger F-Series Trucks 0 03-12-2011 01:04 PM
Tags
1999, 2000, 350, batteries, battery, charge, diesel, f350, ford, killing, long, regulator, replace, truck, turbo, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
