WTB: rear differential asmbly 3.55
i sheared my spiders off and cracked the carrier, reused everything else, just flushed the case out real good with brakleen, drove 20 miles and changed fluid again and recleaned, its been a good 15k since i did it with no probs, nice and tight no noise, i can take pics of the carnage, i saved the pieces of what was left
The VSS broke off inside and damaged the gears and limited slip carrier.
I have never worked on this style differential, can you just unbolt the bearing caps and replace the carrier assembly without total removal and disassembly?
I forgot that I want to also change my ratio and would have to change the pinion gear...
Vince
Vince
