Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #46 (permalink)
Old 10-22-2007, 05:16 PM
Big Bad is gaining momentum as a positive member of FTE.Big Bad is gaining momentum as a positive member of FTE.
MM&FF are idiots. That 7.0L experimental is a Hurricane/Boss engineering exercise codenamed 777 for 7.0L, 700 hp @ 7,000 rpm. Apparently it must make over 700 hp on E85.
SOHC, 2V, 2 spark plugs per cylinder. You can find better pictures of the engine in Don Bowles car on the 'net. You'll see it has a Modular style timing chain cover, a dead giveaway for overhead camshafts. Also note how far back the #1 and #5 intake runners sit from the front of the engine. Does MM&FF really believe Ford just wasted all of that space for no reason?
The video gives a better idea: http://www.nmratv.com/index.php?playlist=1
  #47 (permalink)
Old 10-22-2007, 05:47 PM
SMIGGS's Avatar
SMIGGS has a good reputation on FTE.SMIGGS has a good reputation on FTE.SMIGGS has a good reputation on FTE.
Regardless of what "type" of motor it is, lets hope we actually see it put into production.
I would imagine it would be de-tuned somewhat for production but a 700 hp F150 would get the job done...
__________________
SMIGGS
2000 Eddie Bauer
1999 F-150 4x4
  #48 (permalink)
Old 10-22-2007, 06:10 PM
It's essentially a big bore version of what we'll see (6.2) in the F150. It should make 425 hp in the F150.
Blue II on BOF says there is a "TwinForce" 6.2L (DOHC, 4V, direct injection, twin turbo) that has made over 650 lbftf in testing and will get gas mileage on par with a 5.0L range V8.
  #49 (permalink)
Old 10-22-2007, 06:17 PM
The 777 is essentially a big bore version of the 6.2 we'll see in the 2009.5 F150 which should make ~425 hp.
Blue II on BOF informed us that a "TwinForce" 6.2 has made over 650 ftlbf in testing and gets gas mileage on par with a 5.0L range n/a V8.
Would you be interesed in a DOHC 4V, GDI, TT Boss 6.2 that makes 650 ftlbf and gets around 20 mpg hwy EPA?
  #50 (permalink)
Old 10-22-2007, 06:32 PM
SMIGGS's Avatar
Sure would, but I will believe it when I can go and buy one.
__________________
SMIGGS
2000 Eddie Bauer
1999 F-150 4x4
  #51 (permalink)
Old 10-25-2007, 10:20 AM
I've heard it will be out as soon as '11.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
