rear-end chatter
Old 10-03-2007, 01:04 PM
tony mathers's Avatar
tony mathers
tony mathers is offline
rear-end chatter
My 2002 psd seems to lock-up the rear-end sometimes when turning. Even in 2wd it will clunk and sound terrible. It started doing this shortly after mechanic changed gear-oil in rear-end. Any ideas?
Old 10-03-2007, 01:12 PM
cleatus12r's Avatar
cleatus12r
cleatus12r is offline
Butt-Head
Received 1,966 Likes on 1,105 Posts
Some trucks were equipped with what is called a "limited slip" (although I like to call them "limited traction") differentials that use clutch plates to minimize the "one-wheel-wonder" effect commonly associated with "open" differentials.
These clutch plates require an additive to be used that allows the clutches to slip and release. Without the additive, clutch binding and friction material failure are common.
I would have the tech add "friction modifier" to the fluid. It will take a little bit of driving around corners to work into the friction material, but you should be fine.
Old 10-03-2007, 08:13 PM
F350-6's Avatar
F350-6
F350-6 is offline
I agree. Sounds like a friction modifier issue. Just make sure the mechanic did use a synthetic fluid and not the old 80-90w gear oil.
Old 10-04-2007, 08:25 AM
tony mathers
I couldn't remember if you were supposed to use synthetic or if you were NOT suposed to use synthetic. Also do I have to use Ford's synthetic or just any additive for the rear-end.
Old 10-04-2007, 08:38 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
4X4 IN REFUGIO is offline
Yes....Friction Modifier.....Needs to be add and is required in the rear end differential of your truck.
Old 10-04-2007, 09:15 AM
GoBigOrange's Avatar
GoBigOrange
GoBigOrange is offline
rear end noise
Tony,
These guys are right. I was on the way back from Texas one night when mine sounded like it was coming out. We were at a rest area and it honestly sounded like the lugs were loose on one side when you pulled up (you know that rythmic clunk at slow speed). I checked everything and figured it had to be the rear but at 3am didn't have much choice but to drive on. Had it checked by the stealership and they added friction modifier (they said there is a service bullitin about it) and it stopped. They also recommended that I change the fluid about every 15k miles if pulling a trailer.
Good luck,
John
2003 F350 CC 4x4 dually, 6 speed, K & N FIPK, Quadzilla Commander, Superchips Max Microtuner, RDS 91 gallon tank/toolbox combo,
Old 10-04-2007, 09:39 AM
rugermack's Avatar
rugermack
rugermack is offline
The tag on my diff says it came with syn in it. If you use Royal Purple you don't need friction modifier. The tech should have known better.
nmclea02
01-27-2011 12:33 PM
MikeSD
05-15-2004 01:33 PM
wiggy
02-11-2004 03:35 PM
54Guy
01-19-2002 09:15 PM
OneUgly58
10-30-2001 06:32 PM
Quick Reply: rear-end chatter
