My 2wd 1985 F-150 has NEVER had the rear differential fluid changed. It has over 170K miles, and I was wondering if it would be wise to change it now, or is it too late and should I leave it alone?
change it now! juist because you go over on your engine oil change doesnt meen you wait another 3000! If you have a limited slip dont forget the friction modifier. I use regular 75-90 gear oil.
