390 specs - Ford Truck Enthusiasts Forums
390 specs
Old 10-02-2007, 10:34 PM
adamraaron adamraaron is offline
adamraaron is starting off with a positive reputation.
Thumbs down 390 specs
Hey guys. I asked a question about the 390 in some other thread and they yelled at me and redirected me here.
Anyway, I have a 1973 Ford f-350 super camper special that I was interested in gaining a little more hp/tq. I have so far ordered a holley 600cfm carb and a new edelbrock dual plane manifold. I bought this truck from my dad which he semi restored and the truck is in nice condition. Can anyone tell me the Cam profile type of these truck engines? Am I right to assume they probably somewhat follow the cam specs of a rv cam since they are made for pulling?
And mainly, I want to get "better heads" what would you experts recommend for this pretty much 'stock' motor?
And since i am not that mechanically inclined (yet/learning) can someone clearly explain the MSD ignitions role, and how it helps with power?
Thanks guys, sorry for the lengthy questionnaire...
Old 10-02-2007, 11:47 PM
Hypoid's Avatar
Hypoid Hypoid is offline
Hypoid has a good reputation on FTE.Hypoid has a good reputation on FTE.
Welcome aboard! I'd like to apologize in advance: If it seems like I'm yelling, it's because I don't see so good. LOL
I don't know a whole lot about cam profiles. Someone else will have to fill in there. I can tell you that the stock grind for a truck is pretty mild. The typical truck engine also has a lower compression ratio than a comparable car engine.
If you plan on working your truck like...well, like a truck, you probably already have the better heads. A little port matching and clean up may be all the benefit you'll have use for.
The 600 CFM 4V carb is perfect for these engines.
I think just about any electronic ignition system will produce a hotter, more reliable spark. Never spent the big bucks for aftermarket stuff. Stock systems handle my current needs.
Hope this helps, Mike
Old 10-03-2007, 12:11 AM
Do you guys happen to know what kinda hp increase i might see on this stock application as well with just the intake manifold and carburetor add? I think it's rated at 201hp/376tq as is standard...any educated guess would be appreciated. By the way... I'm not looking to make this thing some badass roadster... I just want nice reliable power compared to a modern truck and good torque to pull whatever. I was think 300hp/400tq would be just fine.
I know the compression ratio is 8.6.1. Probably can't get away with anymore than that running 87 octane right?
If anyone can reply on easy top end builds that would make this goal attainable... I would be very grateful.
By the way.. this forum rocks.. I've been reading peoples post and replys for about 2 hours now... FORD geniuses....
Old 10-03-2007, 09:36 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Cam profile ? Lift is less than .400, duration is less than 200*@.050. Hardly equal to your average RV grind today. With the stock comp ratio, the best cam to replace it with will be a Comp Cams 268H. This will give it a bump in the dynamic comp ratio, making it seem to have something like another point in the static ratio (from 8 something to 9 something) Get headers ASAP, that's the choke point on 390's, the heads are fine as is for what you want. MSD (to me) isn't a cost effective ignition for stock to mild builds. Replace the points with an electronic conversion module & a hotter coil. This setup will do wonders for not much money. The $300 you'd spend extra for an MSD system will net you nothing you'd feel in the "seat-of-the-pants" meter. Spend that on a cam & headers instead. With the Comp 268H, ignition module, intake, carb and headers, your 300 hp/400 tq is easy to reach, if not exceeded
Old 10-03-2007, 09:49 PM
Old 10-03-2007, 10:25 PM
Baddad457
Thanks Baddad for the good info.. I've seen many of comments made by you on this forum after my 5 hour reading session on here. Extremely informative. This was exactly the reponse I was looking for. Thanks for your help.
Old 10-03-2007, 10:26 PM
I forgot one more question.... what kinda headers would you recommend for this application?
Old 10-03-2007, 10:30 PM
What ever you can find that fits and you can afford. You don't have a lot of choices in an F350. Keep in mind though, that headers are a must, whether you do any other mods or not. The stock manifolds just plain suck. Big time. The heads aren't a bottle neck to power on FE's, the manifolds are.
Old 10-03-2007, 10:35 PM
And yet another.... Don't you have to do some modifications to the heads when you install a different cam?
Old 10-03-2007, 10:39 PM
Not with the cam I listed. The stock springs are good to at least .500 lift. Ditto for the rockers. I've used both with a .516 & .523 lift and one cam was a 272 degree duration (advertised not the @.050 lift) and the other was a 296* duration. Both hydraulics.
Old 10-03-2007, 10:41 PM
The Comp 268H is a 268* duration and .494 lift. Smaller than both i used. If the springs on the heads now are old, it would be a good idea to install new ones after the new cam is broken in.
Old 10-03-2007, 10:48 PM
Awesome, thanks again baddad.
Old 10-03-2007, 10:50 PM
No problem. Let me know how many V10's you out pull.
Old 10-04-2007, 11:04 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
Not going to get into a peeing contest, but I can say that my 11:1 390 in the '74 highboy could pull about the same loads as my V10. And the truck itself is about 1500lbs heavier.
And the V10 doesn't try to kill me by carbon monoxide poisoning idling 20 feet away from the garage door ...
And my last highway trip, my V10 got better than 16MPGs, almost 17. Actually, I broke 17, but I'm skeptical of my own calculations...
Old 10-04-2007, 01:38 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
[QUOTE=adamraaron]Hey guys. I asked a question about the 390 in some other thread and they yelled at me and redirected me here.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
info@performancedistributors.com
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
http://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
390 boat motor? 76Ford kid FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-12-2014 04:18 PM
Stock 390 CAM Specs ?? daflentge FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 10-13-2006 04:02 PM
edelbrock streetmaster 390 donsboy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 04-19-2006 12:19 PM
351w torque cam help! bluepartsman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 03-18-2005 10:34 PM
Comp cams XE262H 76 F150 Ranger XLT FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 08-27-2004 08:36 PM
Tags
1973, 360390, 390, big, block, cam, camper, compression, f350, ford, hp, power, rv, special, specs, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
