truck shutters when put in reverse - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-02-2007, 04:55 PM
fisherj fisherj is offline
fisherj is starting off with a positive reputation.
i have a 2005 f-250 superduty 6.0L with the torqshift trans. Just lately it started to shutter for a few sec. when put in reverse. Also a couple of weeks ago while i was pulling a load it would not upshift and the tow/haul light started flashing, so i shut her off and restarted and it worked fine. I was hauling again this weekend and the truck worked great but the tow light flashed most of the time, and now i have this shutter when i put it in reverse. Could this be an eletronic problem or internal?
Please help
Old 10-02-2007, 05:06 PM
chuck06250 chuck06250 is offline
chuck06250 is starting off with a positive reputation.
Are you coming to a complete stop before dropping it in reverse? Both of mine do it if the truck isn't completely stopped. OK otherwise.
Old 10-02-2007, 05:09 PM
Yes. it does it when i take it from park to reverse or drive to reverse
Slow Speed Truck Shutter asterof 2004 - 2008 F150 10 09-14-2014 12:33 PM
Throttle shutter on '13, EcoScrew, 157" chassis? Pool Runner 2009 - 2014 F150 7 02-20-2014 12:43 PM
04 powerstroke misfire/hesitation/shutter when idling or higher RPM Gribbletyler 6.0L Power Stroke Diesel 10 01-06-2014 10:33 PM
7.2 will start but will only idle;no throttle response kpriddy 1999 - 2003 7.3L Power Stroke Diesel 22 09-17-2009 12:04 PM
C6 transmission shutter georgiaford67 Clutch, Transmission, Differential, Axle & Transfer Case 2 12-13-2004 03:22 PM
Tags
05, f250, reverse, shutters, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
