2003 f150 fx4 5.4 (tuneup)
Start with spark plugs, Motorcraft, plug boots, plug wires, something that is better conductive than OEM and delivers a hotter spark. Clean the MAF sensor, clean the throttle body, put in some fuel injector cleaner, or better yet, use some Seafoam that you can find at AutoZone. You can find how to use Seafoam by searching this forum. As for your rought idle, could be because you got some oil from K&N on your MAF sensor, check the IAC valve with an ohmmeter, coudl be defective, could be a varity of other things.
74F100LGM
17
08-24-2014 05:12 PM
dfox
05-17-2002 01:54 AM
