Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-02-2007, 01:49 AM
mvvette97's Avatar
mvvette97 is starting off with a positive reputation.
Anybody have their steering shaft go bad?
I noticed that when driving the steering wheel will catch from time to time. Scared the crap out of me the first time at 60mph.. I did find out it is the knuckle in the steering shaft between the steering gear box and the column. Just wondering if this is common?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-05-2007, 10:38 AM
IrishMike's Avatar
IrishMike is starting off with a positive reputation.
Hello, if by knuckle you mean the round rubber disc that mounts the box to the shaft, yes that happens every now and then, you should be able to get one at any parts house, they usually have them on the "help-tree" in most parts houses. If it is a different part please type in and tell what it is and what truck you have.
  #3 (permalink)
Old 10-05-2007, 10:52 AM
Tom84150 is starting off with a positive reputation.
Some people call that the disc assembly a rag joint, in case you need to explain it to a parts guy. I found them at NAPA years ago when the same thing happenned to a '68 F250 I had.
-Tom
  #4 (permalink)
Old 10-05-2007, 12:08 PM
mvvette97's Avatar
ok, I think you guys are talking about the piece that is down by the steering box. I'm talking about the part that is closer to the firewall of the truck. it is kina like a CV joint.
  #5 (permalink)
Old 10-05-2007, 12:39 PM
cleeE150 is starting off with a positive reputation.
just looked at my 89 theres rag joint near steering gear, and another joint on end of steering colum has bolt going trough looks like bushed shaft coupling, dont know how that would bind up, maybe binding in ,colum? sometimes could be power steering going bad, or steering gear itsself, binding, dont know,hope fully somebody can give you better imput, let us know what it takes to fix it,
__________________
" 1989 E-150 302 aod4-speed full conversion "
  #6 (permalink)
Old 10-07-2007, 10:00 PM
5_labsownus's Avatar
Real Trucks No Sparkplugs
5_labsownus is gaining momentum as a positive member of FTE.5_labsownus is gaining momentum as a positive member of FTE.
Yes the u-joint at the top does/can go bad like the one in my 82! replaced it with a borgson shaft and like the feel of it over the stock.
Rod
__________________
WV Chapter Member
2002 Escape
1999 F250 4x4 SD Crew 7.3 "The Beast"
1999 Mercury Sable
1982 F250 4x4 Known as BullDog! wilh a 300 l6, Offy "C", Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
  #7 (permalink)
Old 10-07-2007, 10:23 PM
mvvette97's Avatar
Quote:
Rod
where did you get this borgson shaft from?
  #8 (permalink)
Old 10-08-2007, 09:47 AM
Oops "Bergeson"
The shaft I used is the 985.
http://www.borgeson.com/TruckProductFord.htm
__________________
WV Chapter Member
2002 Escape
1999 Mercury Sable
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
