is my starter going bad? - Ford Truck Enthusiasts Forums
Old 10-01-2007, 04:56 PM
emfitz79 emfitz79 is offline
emfitz79 is starting off with a positive reputation.
Hey,
I just bought a 72 f100. It started fine about ten times. Now I have to try 5 or so times to get it started. The battery is new. When you turn the key it turns over for about three seconds then stops turning and makes a little whining/spinning noise. What is this noise? Is the starter going bad? Sometimes if I just turn the key a few times quickly it seems to help get it started instead of turning the key and holding it. Thanks for your help!
Old 10-01-2007, 08:18 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
i dunno. once in a blue moon mine makes the most loudest embarrasing screeching sound ever imaginable.
Old 10-01-2007, 08:39 PM
makz06 makz06 is offline
makz06 is starting off with a positive reputation.
Sounds like the Bendix is getting stuck or not engaging. I believe you can still get the parts to repair instead of getting a whole new starter.
Old 10-02-2007, 12:50 PM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
I'm with makz06 on the bendix drive is bad. You can replace just the drve, but with the cast of the drive and a rebuilt starter being real close nad ya got to take the starter out anyway, I would put in a whole starter. IMHO
Old 10-02-2007, 01:17 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
Those same symptoms can also be attributed to a bad connection or bad cable. Check and clean every connection associated with the starter circuit on the big cables. Battery,solenoid,starter,and grounds.
Old 10-02-2007, 05:53 PM
Seems to happen to me quite often on the old vehicles I don't drive on a regular basis. Right now both my 72 F100 and my 68 Cougar exhibit that symptom on a fairly regular basis. The F100 will always start engaging again after I keep turning the ignition key. When my Cougar does it I have to crawl under the edge and rap the starter a couple times with a hammer and "loosen it up" and then it will engage again at least for the next few turns of the key. I plan on replacing both starters but haven't gotten around to it yet.
Carb "cough" with smoke, now a new engine noise? fordtrck302 1978 - 1996 Big Bronco 2 03-30-2015 02:12 PM
2002 7.3 not starting....help carbonfootprint 1999 - 2003 7.3L Power Stroke Diesel 21 10-21-2013 06:06 PM
Tips for Self Testing the Ford Excursion or F250 Rear Parking or Back up Sensor System Solaratrd Excursion - King of SUVs 0 02-01-2012 11:12 PM
2001 Escape Will Not Start michael101 Escape & Escape Hybrid 4 05-16-2010 03:56 PM
2006 / 6.0 diesel - Will not start -- HELP dditto 6.0L Power Stroke Diesel 10 11-07-2008 07:57 AM
Tags
2002, bad, explorer, f100, signs, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
