First chink in the armor.....let the insults fly!!
First ***** in the armor.....let the insults fly!!
Impeding transmission disaster or annoying trait???
Have about 2500 miles on the Tundra.....
During 1st trip of the day, until things warm up a tad, the trans slips or "flashes".
In other words, the RPM rises with no corresponding increase in speed. (almost like it's low on fluid)
Trans functions fine the rest of the time.
I know I need to bring it in but I fear the standard dealer response; "Cannot duplicate"
It'll have to sit overnight to get it to repeat.
2 previous gripes about the truck are kinda me not looking too far into it.
The radio display is invisible during the day..........because dumas me has my sun glasses on. But I still can see the numbers on my Ford with glasses on/off.
Even though the Tundra tow hooks are way recessed, there is a built in "guide" that would keep a strap at an angle away from the bottom of the truck.
The Ford tow hooks are still a better design.
1 new gripe is that Toy uses a non-cartridge type filter....you have to spin off the housing, replace the filter, re-install housing. A drain at the bottom of the housing and a special plastic tool that comes with the filter does drain the housing.....but it's still a PITA compared to a spin on cartridge. (My VW TDI used a similar set up)
The frame issue has always been moot to me even though I think the Ford 150 does have a beefier set up on paper
After having the Tundra on the lift to change the oil, I noticed the front boxed section is at least the Ford's equal......the center section is quite unique; It's a C-channel but uses another piece of steel inserted inside the channel. It's riveted every few inches. Even though it's technically a C-channel, it is "double walled" and nearly connects to make a box. Don't understand the reasoning.....seems like a lot of extra work.
The last 1/3 of the frame is standard C-channel....just like my Super Duty.
I promised all the pros and cons as I find 'em.
Originally Posted by xtrford
I always hated the cartridge style oil filters, my wife has a TDI as well.
Does your tranny do this when shifting through all the gears??
Right on, at least the TDI has an intergrated "nut" on the housing to turn it. (used a large Crescent)
I had to run and find a 65mm fluted tool to unscrew the Toy housing.....you can ALMOST get a strap wrench around it.
Negative on all the gears....just 1st gear from a dead stop. Does it maybe twice and then operates normally.
On the Tundra site, I've got 2 others saying they have similar symptoms.
Originally Posted by DearbornDerek
Would I be correct to assume (yeah, I know not trying to make an *** out of either of us ) that the trans is sealed and you can't check the level? Maybe it does need a topoff? Just throwing out ideas.
Sealed is correct...........and it crossed my mind but I would think low fluid would cause it to slip at every take off.
