Throwing Oil
Throwing Oil
I've got a 390 (supposedly) that's running like a swiss watch, but is throwing oil like all get out. I don't know if it's from the rear main or someplace else on the rear of the engine (just put a aluminum intake on about 8 months ago). Would the oil pressure go down if the rear main was going bad? This engine only has about 8 thousand miles on it.
Thanks,
Butch Whitehouse
'74 F-250 4X4 (The object of my affliction!)
'96 F-150 4X4
'99 D'Elegant E-150 Conversion
Thanks,
Butch Whitehouse
'96 F-150 4X4
Throwing Oil
You may well not see a significant reduction in oil pressure if the rear main was leaking.
There's a good chance it is a result of your manifold swap. The FE is notorious for leaking between the block and the manifold at the rear. Take a good luck back there and see if there is oil on the back of the block. You should be able to tell right away if the leak is up there or somewhere down below. How did you seal the rear of the manifold to the block?
Millenium Edition
04-14-2012 09:24 PM
Craigwell
10-19-2010 03:25 AM
ford racer 02
12-22-2005 06:52 PM
