Transmission Fluid Capacity 1999 f350 7.3 - Ford Truck Enthusiasts Forums
Old 09-30-2007, 09:47 PM
superrman77 superrman77 is offline
superrman77 is starting off with a positive reputation.
Guys I tried to do a search but it won't let me for some reason. I have a 99 350 7.3 4x4 dually. The previous owner must have lost the owners manual. How much tranny fluid do I need to buy for this truck? What fluid do you recomend?
Old 09-30-2007, 09:58 PM
powerstrokinsmokin's Avatar
powerstrokinsmokin powerstrokinsmokin is offline
powerstrokinsmokin is starting off with a positive reputation.
get 18 qts mercon atf, start with adding 16. don't forget to drain the torque converter. it has a drain plug in that too. then just add from there, ALWAYS check trans fluid at operating temp. 150-170 degrees.
Old 09-30-2007, 10:05 PM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Here is the link to the transmission fluid change, excellent info. The 4R100 tranny holds almost 18 quarts. Many folks buy 20 quarts to be on the safe side.
http://www.ford-trucks.com/faq/1999faq/Maintenance-AutoT.htm
hope you find this helpful
I use Schaeffer's synthetic transmission fluid - It's what BTS uses so it's good in my book.
Old 10-01-2007, 08:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Advice for New E350 7.3L owner sedonaguy27 1994.5 - 1997 7.3L Power Stroke Diesel 0 06-22-2015 05:28 PM
7.3 tranny fluid change Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 11 03-04-2015 12:51 PM
7.3L IDI Turbo-Diesel Fluids and Capacities? WillF250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 06-03-2011 10:41 AM
Trans fluid change on a 2001 and 2007 Headviking 6.0L Power Stroke Diesel 14 08-11-2010 12:12 AM
1997 E4OD TRANSMISSION FLUID CRICKEYDOG 1997 - 2003 F150 1 02-03-2010 08:01 PM
Tags
1999, 350, 73, capacity, capactiy, check, diesel, expedition, f350, fluid, ford, hold, operating, powerstroke, safe, temp, trans, transmission, transmisson
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
