How much horsepower is the 351M/400 block capable of?
Originally Posted by 5.0stang
Just like the subject says!
What is the weak point? The stock rods, stock crank, stock pistons, stock block?
40lbs off the rotating assembly is saving an incredible amount of energy...that sounds like quite the build...with a stroker windsor crank it would lead to a lot of options.
I like a lot of options and think a 4" stroke is optimum for a street rig that you want to keep tires on. Have you checked out some of kits mustang depo has on ebay? I'm not up on the brands and quality.
Depending on application of course lol.
Take a look at a few of the builds from TMI, should give you a semi decent idea for a reliable build, if built properly (4 bolts mains, balanced lighten the rotating assembly, use of a girdle on the bottom end, etc) i think 600 would be bout the max i would feel safe with, but as with any high power motor i doubt that you're going to see any type of long term use just due to the fact that high performance motors are built to be driven and not babied.
Obowersox26
05-04-2015 04:35 PM
