4.0L Leaking intake manifold, coolant leak into oil
driver side rear worst, rubber ate and decomposing
had build up of corrosive crud filling 1/3 of hole
coolant flush every 2 years, distilled water and new antifreeze
Repaired and back from a 2k mile 2 week vacation pulling new 19ft travel trailer Pacific Coast Hwy 101
had been losing approx 1 cup of coolant per month, getting worse
showed up in used oil analysis last oil change
tried GM Seal Tabs and Gold Seal powder twice with no success except making a gooey mess of the cooling system
removed intake manifold gaskets and replaced with the upgraded improved 2 piece Felpro kit design
steps
disconnect neg. batt. lead
remove air tube
set ac compressor off to side on top of radiator-13 mm socket
removed alternator
remove bolts from EGR valve and mount 10mm 13mm bolts
removed plenum-13mm socket
bled fuel pressure off and disconnected and removed fuel rail-T8 reverse Torx socket
removed fuel injectors-release electrical plug clip and pull up on inj.
removed lower intake manifold 10mm bolts
filled upper oil gallery with T shirt rags to catch debris
cleaned all gasket surfaces with wire brush and acetone
reassembled with Felpro intake manifold/plenum gasket set
new Motorcraft fuel injector O rings, KEMS would not seal
had light corrosion in fuel rail injector holes on driver side of rail, tried to clean by burnishing with crocus cloth but would not clean up and seal. used Permatex Hi-Temp fuel and O2 sensor rated copper RTV to fill gap at bottom of upper O ring on each injector and let set up solid to force O ring to maximum seating depth in fuel rail and position past the corrosion spots causing leaks
intake valves clean on back side of tulips, no buildup
interior of upper crankcase valley and rocker arms spotlessly clean
ran well on the vacation. pulled lots of hills on Hwy 101 and Sierras, never under 45 mph. averaged 14 mpg. best it's ever ran
used no coolant
GCVW gross combined vehicle weights 8,800 lbs van and trailer
In the Redwoods
75_92_95
1978 - 1996 Big Bronco
13
07-22-2015 08:47 AM
moddbox
05-26-2014 11:12 PM
chrisPi
05-27-2012 09:05 PM
markh1254
Modular V8 (4.6L, 5.4L)
09-06-2011 11:17 AM
Cardinal
02-27-2003 01:10 PM
