Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-30-2007, 03:02 PM
redneckte's Avatar
redneckte is starting off with a positive reputation.
flywheel ?s
ok 300 302 351 clutches are the same so what about my flywheel if it is from a 10 inch clutch setup can i put an 11inch on it?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-30-2007, 11:14 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
It has to be drilled for the bigger clutch. And also, you can't interchange the flywheels on some of those engines. The 300 is balanced, the early 302 has a 28 oz weight on it, the later 302 has a 50 oz weight on it, and the 351w has a 28 oz weight.
If you have interchange questions about flywheels, starters, clutches, etc. just go to www.partsamerica.com, and plug in all the different year vehicles with the different engines, and write down the part numbers.
__________________
Dave F
1989 F250 XLT Diesel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
