I say its fine. My 85 F150 does it,and our 94 ranger did it.
The ignition system, headlights, tail lights, cd player, interior lights, blower motors, ecm, etc are things that will draw a little bit of power. It is expected for your lights to dim.
how many watts are your headlights? 60? 60 watts/12 volts = 5 amps per headlight. so thats 10 amps, plus all of your exterior lights, plus your blower motor, and everything else, you are probably drawing alot of current.
__________________
88 4x4 300 six, 5spd. granny 1st, reg cab 3.55
85 4x4 5.0L F-One Fiddy Reg Cab 3.55 With a Flatbed
^Now that its 21 years old, it can smoke and drink!^
To the OP - That sounds about right. I think your truck has a 95 amp alternator. If you have any extra things, such as an electric fan conversion, additional lights, etc then you will not have enough juice at idle. At cruise the alternator is outputting enough to satisfy the demand.
Thanks! I'll let it roll until I have problems. I just never had the volt gage move before, it always stayed right in the middle regardless of load or engine speed. I think volt regulator on the alt is the problem. As long as battery stays charged all is good. I'll find out this winter.
__________________
The Only Dumb Question is the One You Didn't ask!
__________________________________________
95 Pontiac Bonneville SE 207K
00 Ford Ranger XLT 2WD 3.0 117K
06 Ford Taurus SLE 44K
My Explorer does the same thing. Its nothing to worry about. She really gets dim when it is night time, I have the lights on (i have a visor so there are more lights), electric fan turns on, power inverter is on and the defrost is running.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
Got another alternator( no cost as I have lifetime warr) and all is good. I got 14.7 volts at battery with car at idle at about 1200 rpms (Not fully warmed up). 14.6 volts in drive with RPMs at approx 1000 and with all lights and fans on volts were 14.4. Volt gage doesn't move from dead center! All is good for now!
__________________
OK, good feedback & to hear you finally got this one solved. Thanks for closing the thread out.
Sounds like that last alternator had problems, as it should have been able to handle the lights load at idle, anyway it's history, as it should be!!!! lol
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles, but trifles make perfection & perfection is no trifle (Ben Franklin)
Your signature is a sign of a job completed, autograph your work with excellence
