1989 Ford F150 5.8 L Timing Problem. - Ford Truck Enthusiasts Forums
Old 09-28-2007, 06:47 PM
scraperbabe scraperbabe is offline
scraperbabe is starting off with a positive reputation.
My 1989 Ford F150 5.8 L stalled at a red light a couple of days ago and wouldn't start again. My husband thinks that he has everything fixed except for the timing. However he is having problems adjusting it. Is there anyone who could explain exactly how you correctly adjust the timing? Any information would be greatly appreciated! Thanks!
Old 09-28-2007, 06:56 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Pull out the SPOUT connector-shorting bar by the distributor.
Hook timing light on number one spark plug wire.
Loosen the distributor hold down bolt.
Start the engine and turn the distributor until the pointer points to 10* BTDC.
Tighten the hold down bolt and recheck.
Put the SPOUT back in and remove the timing light.
This says 5.0 but your 5.8 is the same.
1989 F250 5.8L starts and cuts off. If I flutter the gas pedal after starting I can keep it running MUDHAWG5 Computer Chips & Tuners 3 11-08-2012 03:02 PM
carb to fuel injected big-red-f350 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-17-2012 02:58 PM
EFI to CARB conversion help quadracer173 1987 - 1996 F150 & Larger F-Series Trucks 21 06-03-2011 12:37 PM
No power to fuel injectors ChurchBuilder 1987 - 1996 F150 & Larger F-Series Trucks 22 10-16-2006 10:23 PM
Adjust Timing - '86 F-150 w/ 5.8L 351 space-debris Performance & General Engine Building 8 03-15-2004 03:40 PM
Tags
1989, 302, 58, 58l, 95, adjust, check, f150, f250, ford, issue, issues, set, spout, time, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
