You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I hadn't realized that the compressor is a "new scroll compressor", but then again I'm not sure what was used before '07. But this could possibly explain why older Expedition owners aren't complaining about poor A/C performance at idle or low speeds. New isn't always better!
My Expy has been back to the dealer three times for poor a/c performance. They have basically replaced almost everything and, while it is much more effective then it was, it still has lackluster performance at idle and anytime the exterior temp is over about 95.
The results from its last visit were multple calls to Ford, a drive in a new truck, and a report of "operating within normal limits." I really like my service manager, so I asked him what was up. He said the 2007 system has less total refrigerant volume and smaller refridgerent lines. He believes that that is the problem.
More airflow and less refridgerent. I don't design these things, but that seems like a bad combination.
............ would someone find production number's on 07 expy's and then see how many folk's are having AC issue's to get a %age of folk's with the issue ,our's will freeze us out!!!!!,I dont believe every one comming down the line has this issue and has to be a vary small #,suck's if your one of them and they just can't find the problem,try driving a new one off the lot and see if it work's!!!!!.
What is the temperature of the air coming out? What is considered normal?
We couldn't be happier with our A/C performance especially for having an EL, thats allot of cabin room to cool off and ours was great in our two weeks of over 100 in July. Our only issue has been a chemical smell coming out of the vents when the A/C is off. I still haven't made it to the dealer to get that checked out.
__________________
HOOK
09 F150 SCREW 5.4 4x4 I finally got my dream truck
10 Dodge Caravan (I know its a minivan 4 kids don't fit in anything else that can get 25 mpg on the highway)
I don't know the exact temperature (I could just stick a thermometer in there to find out), but my problem is more consistency of temperature than anything else. The system is perfectly capable of producing low temperature air, it just seems not to like to for long stretches of time. I get a lot of fluctuations. They are most noticable in hot weather.
Just picked up a 08 EL XLT and I must say at idle the temps aren't cold. I think there are reasons for this. This expedition has a huge radiator, trans and oil cooler. I believe that the engine is staying so cool at idle the clutch fan does not need to run like it used to. Once moving even 5 mph the a/c is cool. I'll have to figure out the a/c temps one day. To give a example my 06 silverado 1500 will chill the air on max a/c with a ambient outside temp of 98 to 101 degrees to 32 to 34 degrees. I wonder if we ran a 12v pusher fan in front of the a/c condenser would the output temp drop? Is the clutch driven fan controled via electronics or fluid? if it's electric you could program the ecm to command full lock up at idle and improve the a/c output.
I think that you are on to something. I know the a/c clutch is electronic, but I don't know about the radiator fan. Please let us know if you figure something out. I know that the older BMWs used to use a 12 v. "auxillary fan" to help out the a/c system. The simple fact is that when the a/c wants to it is capable of spitting our some damn cold air. Mine has odd flucutations even at speed though - not anywhere near as warm as at idle, but definite fluctuations.
JD you may have low pressure or freezing of your system going on, the compressor would cycle off till it thaws, then crank up again as pressure return to normal. I'd make sure for evacuates the system, dries it, then puts the proper level of refridge back in, if you have too much or too little it can cause the same problem you are describing.
They have done exactly what you are describing at least five times. They have also replaced both expansion valves, the accumulator, the compressor, and the blower control module (not the climate control computer).
I originally thought it was exactly what you describe, however that has been checked out too many times. It doesn't get that "hot humid, my compressor just turned off" feeling, just not anywhere near as cold as it is other times. very hard to describe, but it causes the system to be far less effective on hot days than it could or should be.
My thought was the high pressure switch, but they claim to have tested it and that it is OK.
It is so much better than it was that I figured I would accept it for now and start reinvestigating next summer. It does just fine as long as the temperature is under about 94-95.
I just had my '07 in the shop for the door latch recall and I had them look at the A/C again. Last year, it was much hotter with many 110°F+ days in Phoenix and the A/C would stop blowing cold quite often at idle, this year hasn't been quite as bad and its only happened a couple of times. I explained the problem to the dealer and gave them the TSB #, but they were unable to duplicate, so nothing was fixed. Basically I was told, yes there's a Ford bulliten but it doesn't say what to fix, only that there's complaints. Can someone with access to the TSB's let me know what this says (the dealer wouldn't share)?
Reference
"07-26-3
A/c Compressor - Cuts Out High Ambient Temperatures/seized - Poor A/c Performance - Built Before 11/1/2007"
What worked for us last summer, our first year with an EB auto control....
My wife kept turning down the temp to 50 degrees or the lowest setting when she first got it, so it would cool down faster....
All this does is put the system to full recirulate, of all the hot cabin air, than the compressor would freeze up and even shut down until it thawed out....
Went to the dealer a couple of times, and finaly got this answer, leave the temp at 68 or 70 all the time! She now does this and it greatly improved the first part of the trip with faster cooling down temps, it does seem to work....
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
