94' Ranger 4 Wheel Drive Module - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-28-2007, 01:57 PM
chris9n chris9n is offline
chris9n is starting off with a positive reputation.
...I'm not getting any power to my 4WD module. The fuses are good and there is power going to the fuses. I checked both power lines going in with a DMM....nothing.
Does the power go straight from the fuse to the module?
It's different than the '93 module, so the schematic in the maintenance section doesn't apply for me.
Old 09-28-2007, 10:39 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Welcome.
Fuse #7 (20A) in the Engine Compartment is hot at all times and runs directly to the 4WD module (DG/LG). The circuit runs through a few harness connectors which are part of the main wire harness configuration.
Fuse #7 (15A) inside the Cab is hot in Start or Run and also runs directly to the module. However, there is a splice in the circuit and another wire runs to the 4WD switch. So this fuse actually powers both the module (W/P) and the switch (R/Y).
Old 10-01-2007, 09:49 AM
Thanks Rockledge!!
So as a test, I COULD run 2 jumper wires straight from the battery to the connector just to test the system?
Old 10-01-2007, 10:33 AM
Rockledge's Avatar
Quote:
Originally Posted by chris9n
Thanks Rockledge!!
I don't see why not. It's something I would probably try if it were mine. The only drawback I can think of is the switch probably needs power, too, in order for the system to operate properly as a whole. I would also think the key would need to be in the "on" position, as well, when testing.
In any case, you should pull both fuses out before you run 12V directly to the module and/or switch.
And keep in mind that a circuit needs a good ground to operate. There looks to be two ground wires for the module, BK and BK/O.
Old 10-01-2007, 02:06 PM
AWESOME!!
Thanks!
My dad gave me the truck....the 4WD worked for him, then it just quit. I thought it was the module, but I couldn't get power to it to check it.
Also, he changed transmissions, and I didn't know if any of the connections went to the trans 1st, then to the module(in case he messed up connecting stuff back together....LOL)
Old 11-16-2007, 05:24 AM
Ok, I checked the continuity on the 5 pin from the module to the dash switches.....they are all OPEN. Is there a connector between the module and dash that could be disconnected.
I ran the jumpers to the module to get power...that worked.
HELP!! LOL :-)
Old 11-16-2007, 10:06 AM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
The computer controller will not play unless the shift motor position sensor "knows" what gear the transfer case is in check out this link http://www.ford-trucks.com/forums/sh...d.php?t=123542 most of the time this is what a "nothing happens " 4 wheel no start problem is.
Old 11-16-2007, 12:08 PM
Rockledge's Avatar
Yes, according to the '94 Ford Manual, aside from the 4WD switch connector (C206) and the module connector (C204), there is another connector (C202) located "Below center of I/P" which means behind the center of the dash toward the bottom. It is supposedly black in color but in my experience the Manual is not very reliable when it comes to connector colors.
Old 11-19-2007, 08:34 AM
Quote:
Hehe....Before I got a chance to read this, I crawled in the truck on Saurday, to dignose the problem. I was going to pull the shift boot off and start there. Sure enough I saw two black connectors that looked like they needed to be plugged togehter....TA DA!!!! 4 Wheel drive problem FIXED!!! LOL...I was driving around on Satuday on 4 wheel drive.....JUST because I could!! LOL. It's been over a year since the 4wd has actually engaged. Shift motor actaully worked perfectly.
....now...do you know anything about cruise control. It doesn't work.
The connector was actually black!!! :-)
Old 11-20-2007, 10:02 AM
R031Kona's Avatar
That is funny, of course my attempt at problem solving "assumed" everything was pluged in and connected! KISS, that is what I get for assuming, glad my truck had everything plugged in or I would have had a real adventure.
#15 Fuse Causing draw. NEED HELP Kevin562 1999 - 2003 7.3L Power Stroke Diesel 2 12-17-2014 07:50 PM
fuel pump module socalbp 1997 - 2003 F150 8 08-08-2014 06:08 AM
Auto hub module and fuse location. JimiDick 1999 to 2016 Super Duty 3 08-04-2014 01:28 PM
Parasitic battery draw from BSM module Yoam69 Excursion - King of SUVs 15 04-07-2014 10:35 PM
94 E250 4.9 No Spark Flashman 1968-2013 Full Size Vans 4 10-06-2010 09:04 PM
Tags
1994, 94, below, center, connector, control, cruise, drive, ip, located, mazda, module, ranger, switch, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
