rods/pistons??
Old 08-04-2007, 11:24 PM
stock4mustang's Avatar
stock4mustang
stock4mustang is offline
Question rods/pistons??
can i put stock 2.3 pistons on 5.7" chevy rods?
Old 08-05-2007, 03:37 PM
jimdandy's Avatar
jimdandy
jimdandy is offline
No. The pistons will stick out the top of the cylinders. You have to compensate for the extra rod length by moving the pin height in the pistons. Unless you are building an extremely high performance engine, rod length's don't make that much difference, and may not make a difference then. There are a couple of schools of thought on the subject, both pro and con, but no general consensus that I know of. jd
Old 08-05-2007, 06:38 PM
stock4mustang
thanks, ive heard people talk about it but i wasnt sure if they were using stock pistons or aftermarket.
Old 10-09-2007, 07:46 PM
Crossfire's Avatar
Crossfire
Crossfire is offline
Contact Racer Walsh (racerwalsh.zoovy.com). They know as much about 2.3L building as anyone. The Chevy rods needed are the small journal V8 (265/283) or the 250 I6 rods and, no, stock pistons won't work. Longer rods reduce side loading on the cylinder walls, transfer more thrust to the crankshaft and increase piston dwell time at TDC. Personally, I'd go with Racer's stroker crank for 2.5L unless you have the turbocharged SVO motor.
enriched&beyound
06-04-2012 07:10 AM
kellar
18
11-09-2007 07:40 PM
uuranium
Modular V8 (4.6L, 5.4L)
12-12-2005 10:03 AM
61 uni
09-30-2004 06:33 PM
St_alfonzospancakebreakfa
10-20-2003 07:40 PM
Quick Reply: rods/pistons??
