Installed 08 mirrors on 05 today
#61
Originally Posted by wendal
Hay defuser I never heated mirrors before. I was told on my 04 that I did not have to turn them on that they were on the the key was turned to the start position. Is that turn? I that how the heat works on your 08 mirrors? Do the mirrors have marker and turn signal lights? Are they bright?
How much larger are the mirrors than the older style?
thanks
wendelin
thanks
wendelin
#63
There are double throw rocker switches available from places like McMaster-Carr. They spring back to center when released. Guys with older trucks,mines an 04 can use these for a retrofit. I personally don't need the heat feature. I like the power in and out and flip feature. I fold mine back every time I park in a lot.
#67
Originally Posted by Biggziff
Got my 08 mirrors from Dfuser today. Had them installed in about an hour. I used butt connectors to wire them in and had to figure out a couple of wires as they were different than the sheet Bill sent with the mirrors. Bottom line is the install is simple and the new mirrors look good to me. I'm very pleased with the view in the bigger spot mirrors. Dfuser's service was excellent including very fast shipping.
#71
#72
06 f250 with 08-14 mirror upgrade
Can somebody email me the the wiring diagram for splicing 08 mirrors to an 06
f250? I am in able to open the pictures from dfuser.
Email is gasman675@gmail.com
Thanks to all who read this and respond.
RC
RC
#74
There's some detailed info in this recent thread, I just did my '05:
https://www.ford-trucks.com/forums/1...l#post15417384
#75
There are several wiring variations, take care to get mirrors that will plug up to your '05 connectors or come with an adapter. wiring is a piece of cake for me, so I got ones with the newer plug and made modifications so I could use them (I think that is detailed in the thread I linked).
Depending on what you get, you may need to add some extra wiring in your door or plug if it does not match up with what you have now (electrically).
I originally was going to get the more popular 1AAuto ones here: Ford Mirror Pair - 1AMRP00611 at 1A Auto.com
Yet found some much cheaper on Amazon and have been quite pleased with them:
