1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Installed 08 mirrors on 05 today
Old 10-05-2007, 08:44 AM
riggz's Avatar
riggz
riggz is offline
Originally Posted by wendal
Hay defuser I never heated mirrors before. I was told on my 04 that I did not have to turn them on that they were on the the key was turned to the start position. Is that turn? I that how the heat works on your 08 mirrors? Do the mirrors have marker and turn signal lights? Are they bright?
How much larger are the mirrors than the older style?
thanks
wendelin
The 08 mirrors he sells are the OEM mirrors you can see on an 2008 Super Duty. Stop by a dealer or find one on the road somewhere to see the difference in person. The 08's are a good bit larger and provide a much better spot mirror. Yes the heat turns on when the ignition is on. You can get the mirrors with or without the marker/turn signal lights. They are bright enough to pass DOT/OEM specs.
  #62
Old 10-05-2007, 09:32 AM
dfuser's Avatar
dfuser
dfuser is offline
Heat is built in, and is most likely in your specific model managed by a timer inside the truck. The mirrors do have Heat, Side marker and turn signal , and yes they are bright.
  #63
Old 10-25-2007, 10:08 AM
jimmy-six's Avatar
jimmy-six
jimmy-six is offline
There are double throw rocker switches available from places like McMaster-Carr. They spring back to center when released. Guys with older trucks,mines an 04 can use these for a retrofit. I personally don't need the heat feature. I like the power in and out and flip feature. I fold mine back every time I park in a lot.
  #64
Old 10-25-2007, 10:17 AM
Capital Customs's Avatar
Capital Customs
Capital Customs is offline
can you get them in chrome
  #65
Old 10-25-2007, 10:25 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
I saw there was a kit on ebay to put a crhome cover on them,
Nick
  #66
Old 10-25-2007, 10:40 AM
Capital Customs
I saw that also but it does not look as good as my chrome 05 stock ones
  #67
Old 02-16-2008, 10:46 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
Originally Posted by Biggziff
Got my 08 mirrors from Dfuser today. Had them installed in about an hour. I used butt connectors to wire them in and had to figure out a couple of wires as they were different than the sheet Bill sent with the mirrors. Bottom line is the install is simple and the new mirrors look good to me. I'm very pleased with the view in the bigger spot mirrors. Dfuser's service was excellent including very fast shipping.
getting ready to install the mirrors on my '06 what are the wire differences?
  #68
Old 07-02-2008, 05:33 PM
conman3300's Avatar
conman3300
conman3300 is offline
so i have a 2001 f350 and was wondering if the power fold will work on mine because i have those real small crappy ones and would love to update them thanks
  #69
Old 07-02-2008, 05:48 PM
dfuser's Avatar
dfuser
dfuser is offline
Yes they will work. We sellthe mirrors with our switches to make them fold and extend.
  #70
Old 07-03-2008, 12:58 AM
conman3300's Avatar
conman3300
ok sweet thanks that will be the next mod to come thanks i cant wait
  #71
Old 04-17-2014, 07:01 PM
powerstrokebiatch's Avatar
powerstrokebiatch
powerstrokebiatch is offline
Do you know what the wiring is for this? I am trying to replace mine and the colors are not matching up...
  #72
Old 08-07-2015, 08:26 PM
GasMan675's Avatar
GasMan675
GasMan675 is offline
06 f250 with 08-14 mirror upgrade
Can somebody email me the the wiring diagram for splicing 08 mirrors to an 06
f250? I am in able to open the pictures from dfuser.
Email is gasman675@gmail.com
Thanks to all who read this and respond.
RC
  #73
Old 08-07-2015, 08:28 PM
GasMan675's Avatar
GasMan675
Correction
Unable to open dfuser'is pictures.
Thank you again
RC
  #74
Old 08-08-2015, 07:12 AM
asdrew's Avatar
asdrew
asdrew is offline
There's some detailed info in this recent thread, I just did my '05:
https://www.ford-trucks.com/forums/1...l#post15417384
  #75
Old 08-09-2015, 01:14 PM
asdrew's Avatar
asdrew
asdrew is offline
Originally Posted by xvcbnxvj
Which ones did you get? Power or Power Fold + Telescopic? I want to update my 2005 pup dog mirrors and having trouble deciding between the '03-'07 style or the '08s - can't make up my mind.
I got power heated mirrors, manual telescoping/folding. If you're going to spend $$, get the newer style - the older ones still cost about the same if I recall.
There are several wiring variations, take care to get mirrors that will plug up to your '05 connectors or come with an adapter. wiring is a piece of cake for me, so I got ones with the newer plug and made modifications so I could use them (I think that is detailed in the thread I linked).
Depending on what you get, you may need to add some extra wiring in your door or plug if it does not match up with what you have now (electrically).
I originally was going to get the more popular 1AAuto ones here: Ford Mirror Pair - 1AMRP00611 at 1A Auto.com
Yet found some much cheaper on Amazon and have been quite pleased with them:
Amazon.com: MTOŽ Pair Power Towring mirrors for * 2008-2015 * Ford F250 F350 F450 F550 Super Duty Heated Function SMOKE Turn Signals Fold Telescoping 08 - 15: Automotive Amazon.com: MTOŽ Pair Power Towring mirrors for * 2008-2015 * Ford F250 F350 F450 F550 Super Duty Heated Function SMOKE Turn Signals Fold Telescoping 08 - 15: Automotive
Quick Reply: Installed 08 mirrors on 05 today
