Installed 08 mirrors on 05 today
Originally Posted by longcaster
OK, now the big question. I have a '06 F350 and have changed out my mirrors for the '08 power fold/scope mirrors.
I have spliced an '06 plug onto the wires for mirror movenent (left/right, up/down) lights and heat. My truck lacks the relay or module to make the fold & scope work. Just like the glass movement to move one way is +12vdc & the other way -12vdc.
What is or how do I rig up something to work the fold/scope function that can reverse polarity?
What have you guys done?
longcaster
'06 PSD SCREW Banks six gun
longcaster
Originally Posted by LaxPlaya21
Function over form on these. I personally don't like the way they look, but if they help in visibility that is what really matters.
Originally Posted by vatreefarmer
Is textured black plastic the only option on the front cover, or is a smooth paintable version available? I have only about 1/2 inch clearance on either side of my garage door so I'd love the power fold option, but have grown to love the KR painted fronts on my mirrors.
Originally Posted by aortizexcursion
What do the swithches look like, I'd like to keep it looking as stock as possible.
Are they the switches that the 08's come with to fold/telescope.
The switches we provide are 2 Black rocker switches that fit on the cover under the steering wheel.
Originally Posted by dfuser
Nope, the OEM switches from the 08 will set you back about 250 and they do not match any of the previous trucks, w/o making some major changes.
Thanks
#28
There is a lot more work than what you see in the picture.
The switches from the 08 will not fit our current door panel or any where else. They need the mount you see, which in turn requires a whole new door panel, unless you can customize something to make them fit.
In addition you need both switches for these functions to work, as well as the complete door harness with the relay box assembly. None of your existing wiring can support it.
I have messed around with the wiring, but once I saw what all is required to make it work, I gave up on it due to time constraints and cost. I can get all the parts.
#30
