Dunno, what's your engine/tranny setup. If it's lighter duty like a 302 or a 300 then definitely no. The real question here is not HP, but torque. Without engine/tranny numbers I couldn't tell you either way though.
well, if it's a powerstroke with a stock dual mass flywheel, then i would go ahead and change it out now to a single mass flywheel and clutch. then your clutch will hold to about 300hp. that is about all the stockers can hold up to. if you want a clutch to hold 500hp call Dan Vallance at Valair clutch and he can set you up with a clutch for that.
Yeah I'm thinking around 300 Hp, which should be about 500 to 600 Ft. Lbs of torque. That's about max. Makes you think about those tuners in a new way.
Oh yea I forgot about this thread.I put a south bend fb-8 in and am very happy with it. Its a little grabby and takes some getting used to but hooks up without slippage every time.
