Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 09-27-2007, 10:39 AM
brickie's Avatar
brickie brickie is offline
Garage is empty, add now
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Stock clutch and HP
How much can the stock clutch handle.I dont launch the truck just drive it often with max payload.Will it hold up to 500HP?
  #2 (permalink)
Old 10-15-2007, 08:34 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
Dunno, what's your engine/tranny setup. If it's lighter duty like a 302 or a 300 then definitely no. The real question here is not HP, but torque. Without engine/tranny numbers I couldn't tell you either way though.
__________________
300 CI bored .030 over with a 240 head (303 CI). Clifford valves, Comp Roller Rockers, crane cam, Offy intake, true dual headers, x-pipe, pretty spicy.
  #3 (permalink)
Old 10-17-2007, 10:14 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is online now
strokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to all
well, if it's a powerstroke with a stock dual mass flywheel, then i would go ahead and change it out now to a single mass flywheel and clutch. then your clutch will hold to about 300hp. that is about all the stockers can hold up to. if you want a clutch to hold 500hp call Dan Vallance at Valair clutch and he can set you up with a clutch for that.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC 2wd PSD ZF5- 500+hp daily driver.
1994 F-150 4x4 408w- 10.5:1, TFS heads, custom cam, etc.
  #4 (permalink)
Old 10-18-2007, 06:49 AM
brickie's Avatar
Thanks Guys It is a 6.0 mated to the zf 6 speed.
  #5 (permalink)
Old 10-18-2007, 05:48 PM
amish77's Avatar
Yeah I'm thinking around 300 Hp, which should be about 500 to 600 Ft. Lbs of torque. That's about max. Makes you think about those tuners in a new way.
__________________
  #6 (permalink)
Old 11-08-2007, 01:38 PM
stang8893's Avatar
stang8893 stang8893 is offline
stang8893 is starting off with a positive reputation.
I have a 7.3 and it would hold an extra 75 HP put that was about it.
  #7 (permalink)
Old 05-24-2008, 04:30 PM
mitchrock1 mitchrock1 is offline
mitchrock1 is starting off with a positive reputation.
The stock clutch will not hold 500 hp. You need to upgrade once you get past the 80hp tune.
__________________
1999.5 F250 2wd SC 6spd, Auburn LS, AFE2 w/PG7, DP Chip,H2E,MBRP 4" Exhaust,SouthBend Clutch,Midwest Short Shifter,ITP Overboost Annihilator,DI Regulated Return,AirDog,Fuel Bowl Delete,AIH Delete,HPX,203* TStat,CCV Mod,Air Lift SD Bags w/Load Controller,Optima Reds,APC Headlights w/Clear Signals
  #8 (permalink)
Old 05-24-2008, 07:41 PM
brickie's Avatar
Oh yea I forgot about this thread.I put a south bend fb-8 in and am very happy with it. Its a little grabby and takes some getting used to but hooks up without slippage every time.
__________________
03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock,05 6.0 CC srw SB, 95 f250 4x4 woods truck, 68 f100 project
Tags
60l, 64, bend, clutch, f100, fb8, ford, hold, hp, south, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
