Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-26-2007, 09:27 PM
MSF350 MSF350 is offline
1999 Ford F-350
MSF350 is starting off with a positive reputation.
Propane
My dad called tonight and wanted to know if I had heard about the Propane injection systems.
I told him I would post on here and find out about them good, bad, void warrenty, how much gain in hp & fuel mileage?
Thanks in advance for any help.
  #2 (permalink)
Old 09-27-2007, 01:52 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Garage is empty, add now
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Propane injection, when properly tuned, can produce as much as 80RWHP increase. It may increase fuel economy but any savings are offset by the cost of propane.
There are two basic types: Vapor (gas) phase systems and Liquid phase systems.
Liquid phase systems are most common. Liquid propane is taken from the tank to a vaporization chamber where it turns into propane gas the gas is metered into the intake air thru a jet or series of jets. In a multi (usually 3 or 4) jet system the amount of propane being delivered is controlled by opening and closing jets. The result is incremental (step stair) increases in propane as need increases. Single jet systems provide a constant flow of propane no matter what the need. Both of these systems produce periods of excess propane and other periods of insufficient propane.
Vapor phase systems draw propane gas from the storage tank. A constantly variable regulator delivers the propane in amounts proportional to the need at that moment.
As need increases the propane flow is ramped up as need decreases the flow ramped down, its like turning on a faucet you can adjust the amount of water to suit your requirement.
Vapor phase systems are safer because there is no way droplets of liquid can enter your intake air flow. Liquid phase systems can allow liquid propane droplets to enter the air flow should certain critical components fail. Liquid propane in your engine will ruin the engine and your day.
My system is the Powershot 2000 a vapor phase system. I use it when I tow my fifthwheel trailer in hilly terain. It helps a lot.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 09-27-2007, 09:01 PM
1999 Ford F-350
Thanks for the information. I would like to have it when pulling my horse trailer. But does adding this void your warranty?
  #4 (permalink)
Old 09-28-2007, 12:06 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.
I have also seen a post where one propane user said that he got reduced propane pricing on tank refills since he was using it as vehicle fuel. The price difference he quoted was pretty big, which would certainly justify the expenditure in the long haul if he is right about the discount. Otherwise, what I've heard is that propane is economically justifiable as long as the price for proane is equal to or less than the price of diesel (roughly).
Here's the other thing. You've got to have gauges to protect the engine. It can get awfully hot awfully fast if you're not aware of what's happening, and then you're faced with damaged parts that aren't cheap to replace.
__________________
Pete (F250_) -- PAA#19
'02 F250 PSD, CC, SB, XLT, 2WD: 231K miles
Basic, low cost, not really performance enhancing mods.
'03 Excursion PSD, 2WD, 165K miles - Stock.
http://guzzle.rbmicro.com/7pt3/Mods.html
  #5 (permalink)
Old 10-02-2007, 10:57 AM
Phydeaux88's Avatar
It will definetly void your warranty
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
