Steel or stainless won't affect flutter. You will more than likely get a little flutter with the ebay Y-pipe. My dad has the steel one because that was the only one available at that time, the stainless y is a somewhat recent addition.
Surely there is someone out there NOT affilliated with the Ebay sites that has done a real honest to goodness before and after DYNO Testing of the Y-Pipe Mod???????
Not that I don't believe Ebay sites or those who have invested the Money and Time.....
My 2000 F-250SD is just about ready for some serious exhaust system work....thanks to all the Mag Chloride on the Idaho roads. Almost convinced to go with the Y-Pipe but can not afford any possible drop in Low End Torque.
You won't lose low end power. In my experience you actually gain low end. The necked down stock Y-pipe is only to eliminate flutter, thats it. Performance only improves by removing the restriction point.
Isn't that made from PIECES from Summit, not a complete pipe available that way to begin with?
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased! I've been wrong before, I'll be wrong again. Just wait and see.
I just had the ebay y-pipe installed. I had the 99-2000 McD styled pipe. This is a new truck for me, my other 00 V-10 is a 2 wheel drive. I had a custom pipe built for that one 2 yrs ago. The Ebay pipe fit good, cost me $100.00 to have it installed, I have a filter minder gauge on the air inlet tube behind the MAF.. The increased flow & vacum was very apparent, up to 15 from 9 (in H2O )at WOT. the tires smoke off the line easier as well. So I know that mod is allowing the engine to breath easier. one note, it reads the same with my K&N or the paper filter. So now, I will be easy on the throttle & see if I get better Mileage. We are paying $1.33 per liter up here in Vancouver .OUCH !
