Transmission hard shift - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-26-2007, 08:46 PM
Chad Winship Chad Winship is offline
Chad Winship is starting off with a positive reputation.
Hello all, I have a 93 Bronco XLT, 160K miles 5.8 L. Tranny was replaced at the dealer at 50,000 (previous owner)
Last week, the Check Engine Light come on and it starts shifting REALLY hard. Slamming. Especially bad Park to Drive, but even 1st-2nd is a jolt. No prior warning, no missed shifts, no slips, absolutely no indication that the trans was failing, just wham, one day.
I do have an oil leak, maybe valve covers or rear main, that blows oil back onto my undercarriage and trans on the highway. Is there any chance this is some sort of fouled sensor causing bad shift signals? Anything I could look at before I drop $800 on a trans or, more likely, sell my Bronco ?
Any thoughts would be great
Thanks,
Chad
Old 09-26-2007, 10:17 PM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
Have you pulled the codes yet?
Old 09-26-2007, 10:38 PM
No, I haven't. I don't have a code scanner. But if there are other things, hopefully less sinister than a full trans, that might cause this, I'll find a mechanic and pay him for the codes.
Sorry, pretty obvious first step I guess... Thanks.
Old 09-27-2007, 01:22 AM
mrknight01's Avatar
mrknight01 mrknight01 is offline
mrknight01 is starting off with a positive reputation.
Fords shift hard when certain trans codes are present. Ford does this so you will take it in and get it fixed before the hole thing goes bad. most part stores can scan them, try AutoZone it you have one. It probably is just a sensor.
mrknight01's Avatar
Old 09-27-2007, 05:34 AM
Pulling codes
If you have patience you can pull codes with a papaerclip. http://fordfuelinjection.com/?p=13
I bought a thirty something dollar DIGITAL code reader that performs lots of tests.
Old 09-27-2007, 08:40 AM
muckypaws's Avatar
muckypaws muckypaws is offline
muckypaws is gaining momentum as a positive member of FTE.
Why pay someone to read the codes? What would they charge to do this? An Equus 3145 costs $35 and you can keep it forever. Leave it in the truck so when the Fault light comes on and you're away from home you can find out the cause in an instance. Search for 'codereader' on google - you'll find it.
But going back to the problem, yes pull the codes and take it from there... 'let the codes be your guiding light' LOL.
Old 09-27-2007, 08:55 AM
Actually, I was just about to post to ask about that exact unit. I googled "Ford code reader" and it was the first hit. So that unit does work well? I'll have to call around and see if anyone has one locally and if not I'll get one ordered.
My wife is gonna be angry with me....
Old 09-27-2007, 09:05 AM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
And you can check the fluid level for free!
Old 09-27-2007, 09:08 AM
Quote:
THAT, I already did, and it was good and clean. Although if this turns out to not be a full rebuild situation then a full fluid change and filter will be in my future for sure
Old 09-27-2007, 09:23 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
trust me your wife will be much happier with a scanner purchase then a tranny rebuild which by the way for this e4od runs in the area of $1800-2500 depending on the shop and damage.
definatly pull codes like everyone has said. also go to the rear diff and remove the sensor thats sitting on top of the pumpkin, clean it real good and reinstall it. this sensor talks to the tranny and helps it know when to shift. your abs light isnt on by chance is it? is your speedometer working properly still?
Old 09-27-2007, 09:34 AM
You mean I will be much happier if a scanner points to a cheaper solution i.e. sensor. My wife won't be because she's already decided I should sell it for parts.
ABS light is not on and speedo is working. At least as far as I recall... wasn't looking at that specifically but I probably would have noticed.
Old 09-28-2007, 01:30 AM
mrknight01's Avatar
$35.00 is a good price for a scanner but I said AutoZone because they scan for FREE. They want to sell the parts to fix it. *** for other part stores I donít know if they will for free but I bet most will.
Old 09-28-2007, 06:26 AM
muckypaws's Avatar
Yes this reader works very well indeed. I suggest you buy the extension cable for it so you can use it in the cab as some tests require you to press buttons or peddles on the vehicle. Also means you could sit in the dry if the vehicle breaks down in the rain!
Its the best $35 I've spent so far on my truck.
Simon
Old 12-05-2007, 07:52 PM
Graysack Graysack is offline
Graysack is starting off with a positive reputation.
Funny you should mention the comments at the end but that is exactly what my truck is doing now. I did replace the sensor on the differental and still have the same problem, ABS light is on, speedo and OD not working and hard shifting.
Besides that sensor (searched for the transmission mounted sensor the parts store thought I needed for an hour and could not locate) what else should I be looking at for these same symptoms?
transmission speed sensor achyness Performance & General Engine Building 7 03-11-2015 03:58 PM
A4OD shifting issues. Ford Guy 72 1978 - 1996 Big Bronco 2 02-17-2014 11:53 PM
95 bronco trouble codes gjnicholas 1978 - 1996 Big Bronco 13 10-19-2010 01:01 PM
96 F350 transmission problem E40D 66f100prostreet 1987 - 1996 F150 & Larger F-Series Trucks 4 10-29-2009 01:03 PM
E4OD shift Cdy1 Clutch, Transmission, Differential, Axle & Transfer Case 9 01-11-2009 03:33 PM
Tags
58, 94, 95, c6, drive, e40d, f250, f5tz7a247a, ford, gear, hard, park, shift, shifting, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
