front end shakes!! - Ford Truck Enthusiasts Forums
front end shakes!!
Old 09-26-2007, 08:02 PM
wesw0000 wesw0000 is offline
wesw0000 is starting off with a positive reputation.
front end shakes!!
i have an 86 f-150 302 efi. when i get up to about 60 miles per hour, the front end shakes and makes a "thud" noise. i replaced the upper and lower ball joints because they were worn and i thought that might be the problem, but it still does it. it feels like your driving on a really rough road when it starts acting up. any suggestions would be helpful, thanks alot.
Old 09-26-2007, 08:15 PM
Duncan10's Avatar
Duncan10 Duncan10 is offline
Duncan10 is starting off with a positive reputation.
Front wheel bearings. Tires out of balance or out of round or sidewalls failing. Try swopping tires around or borrow some different ones from a buddy.
Old 09-26-2007, 08:36 PM
IrishMike's Avatar
IrishMike IrishMike is offline
IrishMike is starting off with a positive reputation.
Hi, you may want to check the radius-arm bushings, if they are worn it can make some noise.
Old 09-26-2007, 09:07 PM
gearhead351 gearhead351 is offline
gearhead351 is starting off with a positive reputation.
Quote:
I doubt this could be your case but its an FYI, If a drive shaft has a bad U-joint or its not set in right it could do that. I had a friend who had the same issue. turns out he put the caps from the u joints on top of the tangs on the axle. Presto shakes at freeway speeds.
Old 09-28-2007, 07:22 PM
hi, i tried swapping tires still bad i replaced the wheel bearings about a month ago so theyre good. i took the tires off everything seems tight. the only thing i havent replaced is the tie rod ends but they seem ok no slack. im at a stand still, thanks so much.
Old 09-28-2007, 08:01 PM
IrishMike's Avatar
Hi, I guess you checked the radius arm bushings, so check the shocks, make sure they are not "sticky/stuck" ,this can happen if they get bad or bent, check rotors and see that the calipers are releasing and make sure there is not a "chunk" missing. You would not believe some of the things I have seen happen to trucks. You have checked your ball joints and tie rods tires and wheels.This is a 2-wheel drive? Check the steering box, make sure it is solid as well as pitman arm is good shape. If I can think of some thing else I will add in with it. It is hard to say with out looking at it first hand.
Old 09-28-2007, 09:10 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
I had something similar happen with an 82 F150 2wd...turned out to be the bolts holding the axle pivot bushings were worn and the bushings were slapping side to side.
Old 10-01-2007, 02:41 PM
well i replaced the inner and outer tie rod ends, and checked all the bushings that i could see, and still it shakes. im at a stopping point. ive spent too much on it. anyone wanna buy an 86 f-150 thats a great truck short of a few shakes and rattles? thanks for all the help guys.
Front end shaking Greenheadkiller 1997 - 2003 F150 5 11-20-2011 05:34 PM
front end shakes bad when i apply brakes AC94EXPLORER Explorer, Sport Trac, Mountaineer & Aviator 10 02-08-2008 02:57 PM
front end shakes greenterror Explorer, Sport Trac, Mountaineer & Aviator 5 01-14-2008 08:53 AM
violent shake in steering on right turn Gladiator 1987 - 1996 F150 & Larger F-Series Trucks 2 08-11-2003 09:21 AM
98 Expy shakes at 60 mph boroarke Clutch, Transmission, Differential, Axle & Transfer Case 7 07-19-2003 09:32 AM
Tags
1994, 2004, 2005, 60, cadillac, cts, end, f150, f450, ford, front, mph, shake, shakes, shaking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
