6-71 blower on a stock 390???
Old 03-19-2002, 11:34 PM
fordtruckin's Avatar
fordtruckin
fordtruckin is offline
Hi, I've come across a free 6-71 roots blower. My question is, the truck i'm about to buy is stock except for the long tube headers and I was curios if I could buy the proper manifold ,carb and air intake and put the blower on. The truck would be a Sunday driver, so it wouldn't get much use. I know little about blowers or turbos so I need expert advice. Will this thing work and if so, how much HP would I gain?
Old 03-19-2002, 11:54 PM
FEina52F1's Avatar
FEina52F1
FEina52F1 is offline
a 6 71 moves 420 cubes of air per revolution (7 psi gives a moderate air temp increase)
a 390 uses 390 cubes of air per 2 revolutions
so at 1:1 (max) you should pickup about 60-80 % torque/power
I figure the hw/engine mods/etc to fit a blower is about 10 times the fair prices of a blower.
no need for any internal engine mods (just bolt it on) unless you are blowing smoke and are going over 7 psi.
when it is finished you'll love
while you paying for it you question your sanity
nothing moves you like forced induction
Old 03-20-2002, 02:39 AM
fordtruckin
GREAT! that's just what I wanted to hear. I was thinkng the other day about how i'm going to make power with this thing because i'm on a limited budget. Then I remembered the blower.
I'm getting the blower free, and rebuilt very inexpensively by a pro.(very good friend of my dad's) hehehehehe. It's off one of my dad's 6-71's. The engine was just sitting there so i asked "can I have that" and he said sure. So, I must need a differant intake manifold. Where to get that cheap? What kind of carb should I use? I already have the air intake picked out. Also, where do I get the pulleys and belts? Anything else I'll need? thank you so much.
Old 03-20-2002, 08:27 AM
FE427TP's Avatar
FE427TP
FE427TP is offline
Blue THunder and Don Hampton I believe both make new blower manifolds for the FE
Old 03-20-2002, 04:07 PM
fordtruckin
Great! How much $? also, what kind of carb and how much cfm do you use? Is there some sort of adapter plate for the top too?
Old 03-20-2002, 05:29 PM
FEina52F1's Avatar
FEina52F1
So where some of the intent of my message has been missed.
The
manifold
drive pulleys
drive belts
dizzy setup
water pump setup
carbs (2 * 600 Vac is close to OK)
fuel system
is going to be a LOT of money
($US I'd guess $4000, a rebuilt 6L71 blower is only worth $400)
Old 03-20-2002, 05:46 PM
fordtruckin
oooohhhhhhhhhhh okay. So that's where all the cost is involved when you buy a blower. I thought they were just ripping their customers off. Well I dont have that kind of money so I guess i'm not putting the blower on then.:-( Well I guess i'll just put on the 4 barrel and call it good fer now. Thanks for your help!
Old 03-20-2002, 05:57 PM
karlsd's Avatar
karlsd
karlsd is offline
You can make a lot of power from that 390 without a lot of money. More power than you'll ever be able to get to the ground, anyway. You already have the headers. Put electronic ignition on it (Pertronix kit -- under $100 even with a new coil), a 4v intake (cast iron ones work fine and are a dime a dozen), and a decent carb ($300 with all the accessories). Next, replace that stock cam with a good aftermarket one (lifters, too, of course). A decent cam and lifters will be less than $200, but figure $300 to cover a roller timing set and other miscellaneous items while you're at it. Finally, the next time you have to pull the heads, have CJ size valves installed and the heads port-matched. All told, you'll be at around a thousand bucks or so, but you'll be well over 300 ponies and have enough twist to melt your tires at will.
Old 03-20-2002, 07:32 PM
fordtruckin
[updated:LAST EDITED ON 20-Mar-02 AT 08:34 PM (EST)]Thanks alot for the engine advice-it's gold.But my day just got so much brighter because as of 5 minutes ago I may not be getting this truck because I found a truck exactly like it, same year and everything. The differances are it's got a 428!!!! and msn ignition, a four barrel, and needs not body work and has all the chrome. It's still got headers and true duals too!! I am so happy i cannnot contain myself!!!!! i'm going to look at it on saturday!!!!!! wooooohooooooo!!!!!!!!!
Old 03-20-2002, 07:58 PM
flyboy2610's Avatar
flyboy2610
flyboy2610 is offline
Do yourself a BIG favor and latch onto that blower anyway. You may not need it now and it may just go into the closet, but you may want it someday and then you'll kick yourself and say "D'OH! Why didn't I KEEP that???!!!"
Old 03-20-2002, 09:16 PM
fordtruckin
We've got 3 or 4 laying around. My dad will never get rid of them he's one of those collector types who doesn't throw good stuff away. Plus, he can't move it without me, so if it ever comes to that I'll pick it up.
Old 03-21-2002, 06:55 PM
nitrous125's Avatar
nitrous125
nitrous125 is offline
Hey man if you wonna get rid of one of those blowers give me a e-mail at holley99@frontiernet.net i would be glad to pay you good for it. I have been tring ot save up to get me one. Thanks
Old 03-22-2002, 12:19 AM
fordtruckin
Thanks for the offer but it's not really something you can sell. Kind of like your grandma giving you a Christmas present and you selling it. Besides, I'm pulling them off of working engines that ajust aren't being used. I would like to help you out. You know now that I think about it, a very good friend of my dad's and mine rebuilds these blowers and turbos for living. He may have some I could buy on the cheap. I'll ask the next time I see my dad.
Old 03-22-2002, 01:06 AM
BB's Avatar
BB
BB is offline
Brandon4point9
General Automotive Discussion
10-28-2014 08:34 AM
Ford_Six
Large Truck
17
11-14-2013 07:08 PM
mustang81
01-24-2013 05:24 PM
Kuskoal
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
03-27-2009 11:17 PM
Quick Reply: 6-71 blower on a stock 390???
