Roush/Saleen blower on 2004-up 5.4 3 valve triton
Old 09-30-2007, 10:15 PM
ech0sh4y's Avatar
ech0sh4y
ech0sh4y is offline
Would roush be the best option for blowers? Or is there another company out there that is a lil be less expensive cause it doesn't have the roush name?
Old 10-01-2007, 10:15 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Probably a good idea to ask in the supercharger section.
Old 10-01-2007, 11:00 AM
Futura427's Avatar
Futura427
Futura427 is offline
Hmmm thats not good for me??? I was hoping to be able to switch when not pulling my trailer?????
Old 10-01-2007, 04:26 PM
Futura427's Avatar
Futura427
Ok Ken. One Question. What do i do when i tow my car trailer? won't the injector timing,ignition timing,shift points..etc need to be different from a performance setting ? Does Roush have seperate programs for what you are doing with the truck? It would be nice to be able to tow AND have performance...just in case you run upon a TUNDRA at a stop;ight..ya know? Still a kid at heart after all these years!! Joe
Old 10-01-2007, 04:40 PM
Futura427's Avatar
Futura427
Hope i'm not asking too many dumb questions here??
Old 10-01-2007, 11:01 PM
ech0sh4y's Avatar
ech0sh4y
ech0sh4y is offline
No such thing as a dumb question my man!!! I'd like to know that as well!!
Old 10-02-2007, 07:32 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
No, Roush does not have seperate programs. You send them your PCM, the send it back with their program. Its one size fits all. If you want multiple programs, and more power you need an after-market programmer from an experienced tuner, preferably on a dyno for the Roushcharger.
Old 10-02-2007, 09:38 AM
mrpositraction's Avatar
mrpositraction
mrpositraction is offline
I found a supercharger called the power works, I also found an old thread on here about it with a dyno graph. It is about $1000 cheaper than the roush. I to am looking to supercharge my new 2007 F150 FX4 this winter.
Old 10-02-2007, 09:50 AM
mrpositraction
https://www.ford-trucks.com/forums/6...ml#post5183310
That is the post I mentioned above. The A/F is gorgeous.
Old 10-03-2007, 03:11 AM
Futura427's Avatar
Futura427
Ken. Do you think the Roush program would be compatible with pulling my car trailer? It does require premium fuel all the time...correct? Thankyou for all your helpful info so far.
Old 10-03-2007, 08:43 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
I would take the factorying towing number and cut it in half as the safe tow limit. Unless you datalog the truck while towing, with a wide band O2 attached (though Roush's tune is very good with A/F ratios), you will not know how much more you can tow, so half the factory number is a good safe margin.
Old 10-03-2007, 03:18 PM
Futura427's Avatar
Futura427
Cut the weight i can tow in 1/2? Heck..then i will not even be able to tow my open cartrailer. I beleive the weight limit is somewhere around 6-7000 lbs. Need to find my brochure. If i had to cut it in 1/2...THAT would make the blower useless to me!! If i understood what you meant right???
  #28
Old 10-03-2007, 04:28 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
You misunderstood. As a generalization, you take the factory tow limit (9K-11K depending on your truck's configuration) and cut that in half when you add the blower (actually, a little more than half)
For instance, if the stock rating is 10K, I'd limit the towing to about 6K lbs. especially in the summer or on steep terrain.
  #29
Old 10-21-2007, 08:28 PM
Powerws's Avatar
Powerws
Powerws is offline
Originally Posted by Futura427
Anyone added one of these?? I have a 2004 new bodystyle FX4 supercab 4x4. I pull a car trailer with it alot.I've been toying with putting a blower setup on it. Saleen and Roush both make nice complete kits. Local "GREAT" FORD dealership installs these on trucks/Mustangs alot. I'd like an actual owners view on how they are??? Worth the $$? Fun factor/powre improvement also...has to be worth it...i'd think? I currently have new Magna flow complete exhaust(cat-back)dual rear exit/ also K+N intake setup. Any other suggestions for upgrades??? ???? Thanks alot in advance,Joe
It would seem to me that if there are plug problems (blowing out) that a supercharger would only enhance the problem! more air, more power, more compression, more pressure! Is this true? It would seem to me that it would hurt the reliability.
  #30
Old 10-21-2007, 10:02 PM
irishammer's Avatar
irishammer
irishammer is offline
There are no plug blow out problems with the 3v motors.
Quick Reply: Roush/Saleen blower on 2004-up 5.4 3 valve triton
