what size jet in a holley
www.holley.com got to the tech section, there is a list of almost all of the carbs in there that tells which jets, power valves, etc that they came with listed in order by list#. Yours is 80508. The other number is a date code.
I have a numerical listing & component parts. I show a 80508 as a 4160, 750 CFM rebuild kit 37-754/ trick kit 37-921. primary jets are shown as .072/ Power Valve 125-65. secondary spring is plain. I have found that sometimes they didn't come with these components but it will give you a starting point. Remember Holleys come out of the box set for sea level. I find jetting down 1 jet size per 2000 ft above sea level is a good rule of thumb.
Thebandit328
11-28-2014 03:23 PM
David Gray
11-19-2004 12:33 PM
luvfordtrucks
09-12-2003 08:12 PM
