what size jet in a holley - Ford Truck Enthusiasts Forums
Old 09-26-2007, 12:45 PM
RustyTrustyF150's Avatar
RustyTrustyF150 RustyTrustyF150 is offline
RustyTrustyF150 is starting off with a positive reputation.
Question what size jet in a holley
Hi , trying to find what size main jets come with a 600 , 750 holley carbs . Is there a website somewhere that has a list / size chart . Picked up a used 750 -vac secondary and i want to make sure its got the right / smallest ones in to start out with .
Old 09-26-2007, 10:59 PM
Putt's Avatar
Putt Putt is offline
Putt is gaining momentum as a positive member of FTE.
You need to get the "list" number off the front of the choke airhorn, without that it is all a guess.
Old 09-26-2007, 11:57 PM
80508
1357
Old 09-27-2007, 10:57 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
www.holley.com got to the tech section, there is a list of almost all of the carbs in there that tells which jets, power valves, etc that they came with listed in order by list#. Yours is 80508. The other number is a date code.
Old 09-28-2007, 12:37 AM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Smile
I have a numerical listing & component parts. I show a 80508 as a 4160, 750 CFM rebuild kit 37-754/ trick kit 37-921. primary jets are shown as .072/ Power Valve 125-65. secondary spring is plain. I have found that sometimes they didn't come with these components but it will give you a starting point. Remember Holleys come out of the box set for sea level. I find jetting down 1 jet size per 2000 ft above sea level is a good rule of thumb.
Jetting a holley 750 for a 352fe? Thebandit328 1961 - 1966 F-100 & Larger F-Series Trucks 4 11-28-2014 03:23 PM
holley carbs skweelr 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-13-2007 03:01 PM
Deciphering Holley jets GeneStoner Fuel Injection, Carburetion & Fuel System 3 12-12-2004 09:10 PM
460 - Holley 750 cfm jetting David Gray Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 11-19-2004 12:33 PM
holley 600 & 750 metering systems luvfordtrucks Fuel Injection, Carburetion & Fuel System 2 09-12-2003 08:12 PM
Tags
37921, 4160, 750, 80508, carb, cfm, chart, f150, factory, holley, jet, jets, jetting, kit, size, trick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
