Cargo trailer recommendations
I'm in the market for an enclosed cargo trailer in the 6'x12' range preferable with dual axles. I've looked at Haulmark, CargoPro and Wells Cargo but I'm having trouble telling the good brands from the bad. Does anyone have any insights that they would like to share?
Thanks
Thanks
Well, I have a 16' Haulmark that I use to haul my Nova...
First, I have to say that I live ten miles down a dirt road with some places that are pretty uneven (small tank traps). Also, I haven't used the trailer very much...probably 20 trips into and back from my place, plus one trip from the Midwest to Nevada...I'd estimate 3000 miles total mileage. I have had numerous problems with the unit. Screws backing themselves out of the aluminum, stripping of screws holding trim, buckling of plastic panels inside due to heat, etc. I got this unit for a very fair price, picking it up at the factory...but I wouldn't buy another from Haulmark. If I lived out on the pavement, I probably would buy another...I believe it is the dirt roads that is doing this unit in.
Wells Cargo and go for the tandem axle< 4> wheels instead of 2 wheels the tandem will sway less,willnot tip up while loading if un hooked from truck,if you have a blowout with a tandem it extra axle will keep you in your lane.Most trailers all come with brakes Good luck...................Paul
bismic
08-10-2015 10:35 AM
BaitGuru
1997-2006 Expedition & Navigator
05-12-2010 11:14 AM
pcctim
04-14-2009 11:45 AM
jimmyq2
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-31-2005 10:17 AM
