90 F250 Wire Color codes for the stereo - Ford Truck Enthusiasts Forums
Old 09-25-2007, 12:28 PM
90F250CT 90F250CT is offline
90F250CT is starting off with a positive reputation.
Pulled my non working radio out to replace with a new one and the colors on the wires aren't what they should be? One bracket is broken (thus the non working part of it all), I figured I would just cut and connect the wires, ive done it plenty of times, right? Ive figured out the red is ground. confused allready
One bracket has these:
Yellow w/Blue stripe
Light Blue w/ Red
Green w/ Yellow
Orange w/ Black
Red (Ground)
The other bracket has these:
Orange w/Green
Black w/white
White w/ Green
Black w/white
Any help would be appreciated. I search the internet and repetedly find nothing.
Thanks
Old 09-25-2007, 12:52 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
Try www.installdr.com, they have lots of good info about wire colors in a variety of different vehicles. Good luck and Welcome to FTE.
Old 09-25-2007, 12:55 PM
matt12's Avatar
matt12 matt12 is offline
matt12 is starting off with a positive reputation.
If you have figured out ground then one should be + hot wire all the time there should be another that is only hot when key is on and the others should be speakers. the only thing with those i can think of is trial and error but that is just what i would do good luck
Old 09-25-2007, 01:14 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Yellow w/Blue stripe - This should be your battery (12v+) wire
Light Blue w/ Red - Check this one with a test light should be hot only when the key is in the run or acc position.
Green w/ Yellow - this is probably the amp turn on wire, it may or may not be used. Look up where the center speaker for an AM radio would be. If there's a silver box with wires coming and going you have a premium sound system.
Orange w/ Black - this is the illumination wire it will act like a ground until the headlights are turned on.
Red (Ground) - as you've already figgered out this one is a bad joke. Make sure it's a ground, I mean turn all the accessories on with the engine running and double check it. A lot of times these radios ground through the chassis.
Tilt steering wiring questions: 79Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-22-2015 11:16 PM
wiring a 77 column in 68 truck? Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-11-2014 12:04 PM
2000 F250 trailer wiring help needed! SVTDriver97 1999 to 2016 Super Duty 3 08-07-2014 08:00 AM
1987 Headlamp Switch wiring diagram clr0gers 1987 - 1996 F150 & Larger F-Series Trucks 2 09-25-2013 01:32 AM
Trailer wiring colors stock from truck side?? 1fixitman 1999 - 2003 7.3L Power Stroke Diesel 2 01-07-2013 10:02 PM
Tags
1987, 1996, 2002, 450, 99, code, codes, color, f150, f250, ford, market, silver, stereo, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
