Studs torque more evenly than bolts because you're only turning the nut at the top of the stud, rather than turning an entire bolt...so you get a more accurate torque reading on your torque wrench and there's less likely to be a lot of variation between the studs.
As a result of that I believe studs are also said to have more clamping power.
