tilt steering lever - broke 3rd time
Old 09-24-2007, 09:33 PM
conan8's Avatar
conan8
conan8 is offline
this is the third time my lever for my tilt steering wheel has broke. It just breaks right off to what it is ever it is hooked up to. The lever isnt broken but it just comes off to whatever it is attached to to control the steering wheel.
Has anybody else had this problem? If so what can I tell the dealer to make sure they fix it right. I am going to take it to a different dealer to hopefully fix it right. still under warranty.
Old 09-24-2007, 10:23 PM
Corey872's Avatar
Corey872
Corey872 is offline
Mine did that. I just mixed up a small blob of epoxy glue, put it in the attachment part of the handle and slid it back over the piece that it hooks to in the steering column. The plastic handle indexes a small metal tab on the column and you pull out (toward the cab seat) on the handle to engage the pieces or push in (toward the firewall) to pop the handle off.
Old 09-26-2007, 11:17 AM
zag's Avatar
zag
zag is offline
Also on that note. You can remove the panel under the steering column and loosen the bolt on the other side of the metal tab, so there isn't so much force being applied to engage and disengage the steering column.
Old 09-27-2007, 08:16 AM
Frankman's Avatar
Frankman
Frankman is offline
Mine was doing the same thing, I just drilled a 1/8" hole in the plastic handle at the front of the metal block that it slides onto and used a hexhead sheetmetal screw to hold it on. The screw sticks out just enough to keep it from sliding off. Just had to remove cover under steering column and a metal plate behind the plastic cover to gain access. Or try a new handle they are $16.95 at the dealer,but it will come off after awhile also.
Building_Fords
01-10-2017 10:09 PM
BVPDiesel
1999 to 2016 Super Duty
01-06-2017 07:31 PM
av8r210
1983 - 2012 Ranger & B-Series
13
04-18-2011 09:56 PM
Explorer Freak
10-31-2009 05:49 AM
FatBrian
13
08-12-2007 05:22 PM
Quick Reply: tilt steering lever - broke 3rd time
