tilt steering lever - broke 3rd time - Ford Truck Enthusiasts Forums
Old 09-24-2007, 09:33 PM
conan8 conan8 is offline
conan8 is starting off with a positive reputation.
this is the third time my lever for my tilt steering wheel has broke. It just breaks right off to what it is ever it is hooked up to. The lever isnt broken but it just comes off to whatever it is attached to to control the steering wheel.
Has anybody else had this problem? If so what can I tell the dealer to make sure they fix it right. I am going to take it to a different dealer to hopefully fix it right. still under warranty.
Old 09-24-2007, 10:23 PM
Corey872 Corey872 is offline
Corey872 is starting off with a positive reputation.
Mine did that. I just mixed up a small blob of epoxy glue, put it in the attachment part of the handle and slid it back over the piece that it hooks to in the steering column. The plastic handle indexes a small metal tab on the column and you pull out (toward the cab seat) on the handle to engage the pieces or push in (toward the firewall) to pop the handle off.
Old 09-26-2007, 11:17 AM
zag zag is offline
zag is starting off with a positive reputation.
Also on that note. You can remove the panel under the steering column and loosen the bolt on the other side of the metal tab, so there isn't so much force being applied to engage and disengage the steering column.
Old 09-27-2007, 08:16 AM
Frankman Frankman is offline
Frankman is starting off with a positive reputation.
Mine was doing the same thing, I just drilled a 1/8" hole in the plastic handle at the front of the metal block that it slides onto and used a hexhead sheetmetal screw to hold it on. The screw sticks out just enough to keep it from sliding off. Just had to remove cover under steering column and a metal plate behind the plastic cover to gain access. Or try a new handle they are $16.95 at the dealer,but it will come off after awhile also.
Fixing my Tilt Steering? Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 1 01-10-2017 10:09 PM
2012 F-250 Super Duty Tilt Wheel Lever HELP BVPDiesel 1999 to 2016 Super Duty 2 01-06-2017 07:31 PM
steering column/tilt steering wheel question katzklaw 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-19-2016 12:40 PM
Early 80's Ranger with horn button on turn signal lever av8r210 Ranger & B-Series 13 04-18-2011 09:56 PM
2004 Tilt Steering Lever lmahle 2004 - 2008 F150 1 09-05-2009 09:16 PM
Tags
2006, broke, f150, ford, lever, steering, tilt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
