Trouble code P0470 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trouble code P0470
Old 09-24-2007, 10:29 PM
CO04PSD CO04PSD is offline
CO04PSD is starting off with a positive reputation.
Trouble code P0470
I've got an 04 PSD with 51K miles and I've been having problems with hessitation and turbo flutter at crusing speeds as well as erratic idle. I have/had a BullyDog Power Hound with a Bullydog intake and 4" exhaust. I removed the power hound before taking it to the dealer and they found the P0470 code and replaced the EBP sensor?? Well that worked for about a day or so and started doing it again. I took it back to the dealer and they're getting the same error code. They said since they already replaced that part there's nothing else they can do since I have an after market intake and exhaust, and that I'd have to put it back to stock. Has anyone ever had this problem with theirs? and if so what fixed it?? Thanks..
Old 09-25-2007, 12:48 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Did you put the Bully Dog Power Hound back on after it got fixed, and then it started acting up again?
Old 09-25-2007, 01:16 PM
CS04F250 CS04F250 is offline
CS04F250 is starting off with a positive reputation.
Nope - I kept it off..
Old 09-25-2007, 01:48 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
I swear what a cop out!!!! They can't fix it and blame it on your exhaust like it really has anything to do with that sensor. I mean... i have seen odd stuff but really now...
P0470 Exhaust Pressure Sensor.
Related codes
471 EPS Range Performance
472 EPS Low input
473 EPS Hi input
Check for damaged pins/ connectors or wiring. Obviously they didn't fix it if it came back. And considering that they fixed it while fumbling (FWF) for a day, it may be a bad pin/connector. Not uncommon on the 6.0!
I tried to make it a PDF for it but that computer just doesn't like me.
Additional causes: Sigrtn circuit open, bad pcm, bad EPS
Old 09-25-2007, 02:12 PM
You may want to post this question in the 6.0L forum (a little further down on the main forum page), or ask a moderator to move it there. We have certified 6.0L techs, as well as a bunch of guys who know these trucks better than I do that may be able to help you out.
BTW welcome to the site.
Old 09-25-2007, 03:02 PM
aldredgec: I thought it was exactly that a cop out. their "tech" couldn't figure out the problem so they blame it on the exhaust. I'm sure they knew exactly what I thought about their service by the time I left that dealer.
What part would I check for bad pins/conectors?? The PCM possibly?
Beerstalker: I posted the same question there as well - thanks for the help.. this site is awesome!!
Old 09-26-2007, 10:14 AM
aldridgec's Avatar
Do you know where the EPS is ? It is the sensor right next to the thermostat housing. Follow the upper radiator hose back to the engine. Check that connector there. See if it looks damaged. In all reality you need a mating pin to check the connection in each pin hole.
Also check the PCM connector behind the driver side battery. Looking at the EPS connector, the sigrtn pin is the top right with the flat side of the connector to the top.
I'm not sure which of the 3 PCM connector it is looks like a 46 pin one, but it is pin 25 of that connector. you will want to ohm between those pins, and also check to see if they are shorted to ground or another wire. It is possible the wires have chaffed somewhere and are touching another ciruit. It can be difficult to diagnose, but possible.
Old 09-26-2007, 12:28 PM
rugermack's Avatar
rugermack rugermack is offline
rugermack is gaining momentum as a positive member of FTE.rugermack is gaining momentum as a positive member of FTE.
The code po470 has to do with back pressure, with new exaust back pressure has decreased, check posts to see if there is a way to eliminate this sensor or fool it.
Code P0470 tube/sensor location ZombiePopper 1999 - 2003 7.3L Power Stroke Diesel 8 02-22-2015 08:29 PM
please explain these Codes. Canadianpowerstroke 6.0L Power Stroke Diesel 12 10-31-2012 12:19 AM
2008 F250 6.4L powerstroke problem**Help TigerfanJSC 6.4L Power Stroke Diesel 4 03-20-2012 01:08 PM
On Vacation ECT and EOT question firedaniel 6.0L Power Stroke Diesel 26 06-13-2011 01:02 AM
OBDII P-0470 Exhaust Pressure Sensor What is this? lannondiesel 1999 to 2016 Super Duty 3 04-10-2010 10:01 PM
Tags
2005, 60, 73, bully, code, codes, dog, fix, ford, p0470, po470, powerhound, problems, superduty, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
