Right turn signal and reving
Old 09-24-2007, 07:38 PM
custom_nirvana's Avatar
custom_nirvana
custom_nirvana is offline
Alright, I have noticed it a few times before but tonight on my way home it did it everytime. When I turn on my right turn singal you can hear my engine rev up and then drop back down but the rev limiter shows no gain or loss. Any ideas?
97 ext. cab 4x4 auto.
Old 09-24-2007, 08:28 PM
93f1505.0L's Avatar
93f1505.0L
93f1505.0L is offline
by rev limiter do you mean tach
Old 09-24-2007, 08:50 PM
custom_nirvana
ya ya i had a brain fart......
Old 09-24-2007, 08:55 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Strange maybe it is the drain with the lights on. Or maybe you have gremlins. I have never heard this one. Someone will be here to help or give suggestions soon.
BTW Welcome to FTE, All your worries are over now. :-)
Old 09-24-2007, 09:13 PM
93f1505.0L's Avatar
93f1505.0L
Im leaning towards the gremlins. lol
Its only the right trun singal? doesnt happen when you trun the lights on or the high beams or any other electronics? what about when you trun the steering wheel?
Old 09-24-2007, 09:18 PM
FARM69's Avatar
FARM69
FARM69 is offline
Is it possible to have some burnt wires in the column or something? Check your volt gauge next time your out and about. However, I'd think you'd be able to see any unusual rpm movement on the tach? Strange.
Old 09-24-2007, 09:20 PM
Jerme's Avatar
Jerme
Jerme is offline
You can get a new multi-function switch at napa, it's not hard or expensive to do.
Old 09-24-2007, 09:23 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
Neal, for the last time, gremlins are on gassers, widgets are in diesels. there is definatly one in custom's truck. he may be in the column as farm said, or he could be screwing with your grounds. definatly a first in my book and i have seen alot of weird things. the only other thing i can say to check is the multifunction switch. i have seen them do some funky things when they start to go internaly
93f1505.0L's Avatar
93f1505.0L
Ya there has got to be something up with the switch. Do your wipers and all work? That switch really isnt hard to replace at all.
Old 09-24-2007, 09:24 PM
c00nhunterjoe
jerme, i started my post first, thats not fair.
if the multifunction switch doesnt do it then i have widget spray on sale right now for 9.95 a can
Old 09-24-2007, 09:29 PM
Neal 97 250
Widgets, Widgets. banghead here. Sorry c00n I will try to do better. My multi switch is going bad too but all it does is squeek.
Old 09-24-2007, 09:30 PM
93f1505.0L's Avatar
93f1505.0L
Man how did you get that stuff so cheap. Will you double my order if I act now?
Old 09-24-2007, 09:32 PM
c00nhunterjoe
yes i will just send cash only
Old 09-25-2007, 12:15 AM
1997F-350's Avatar
1997F-350
1997F-350 is offline
check your tail lights and 3rd brake light. got any burnt bulbs? if not check the wiring in your steering column.
Old 09-25-2007, 12:34 PM
FARM69's Avatar
FARM69
FARM69 is offline
I don't known Coon. Widget just doesn't sound like a term I'd call this one. I think we should introduce the term goblin (a grotesque sprite or elf that is mischievous or malicious toward people).
I've also heard some pretty casey things that have happened with electrical systems. Anywhere from trailer brakes to CB's going out. I never had the column apart before but that switch might be a little bugger to get too.
Quick Reply: Right turn signal and reving
